Old 06-01-2016, 05:15 PM   #31
Left Coast
It's on the backside....on the wall plate face there is a very small button with led light ...push button to turn on, push again to turn off
Old 06-01-2016, 05:38 PM   #32
Ddubya's Avatar
The amp power switch in the wall plate must be on for the antenna to function
Ddubya is offline   Reply With Quote
Old 06-01-2016, 05:44 PM   #33
We get good reception with the Jack antenna.
KING Jack HDTV Antenna Replacement Head for Sensor TV Antenna - Star Marine Depot
Old 06-01-2016, 06:03 PM   #34
The Jack has an internal amp just like the one you have now. If you replace it, you will still need either the wall plate that you have to send it 12v, or the power inserter that comes with the Jack antenna. One or the other, not both.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-01-2016, 06:03 PM   #35
mrpep's Avatar
Should I upgrade to HD antenna?
So remove my amps , ok
mrpep is offline   Reply With Quote
Old 06-01-2016, 06:59 PM   #36
Ddubya's Avatar
Remove any amp that you have installed. Leave the wall plate with the switch that came with the RV. Hook your tv to the tv outlet on the wall plate. Push the switch on the wall plate to turn on the power to the amplifier that is built into the antenna. Locate your local TV station transmitter on a map or app and point the antenna in that direction. Go through the TV channel setup.
Good luck
Old 06-01-2016, 07:49 PM   #37
mrpep's Avatar
This will sound crazy but my Lcd gets less channels than the old tv on a digital converter , makes no sense
Old 06-01-2016, 08:01 PM   #38
Ddubya's Avatar
The new and improved digital transmission system is a kludge. Sometimes it works and sometimes not. Another government improvement.
Old 06-02-2016, 06:42 AM   #39
mrpep's Avatar
So I guess I have an old tv in here but hey it works great! Would have liked the lcd but it sucks , doesn't get any channels in a stable manner. I still find it really weird but oh well
Old 06-02-2016, 10:19 AM   #40
Canadian Member
itat's Avatar
How this is the government's fault?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
antenna, upgrade
