Old 05-24-2014, 05:28 PM   #51
Toy-aholic
Originally Posted by youroo View Post
Attachment 47247Also while you are in the shower,if your hose outlet is at the TOP,change it to the bottom! The knobs will turn correctly,and the whole assembly will drain and not (Freeze) if you just use the Blow out method of Winterizing! Pic. of assy.turned,(Knobs Crooked)! Youroo!! The shut off valve on the bottom is from (Ace HW).
can I ask what the purpose of this is?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 05-26-2014, 07:57 PM   #52
Ksilvi's Avatar
Originally Posted by 5ersabre View Post
It's a nice shower head but does splash more than the original one. When you first turn on the water I always have the glass doors closed as far as possible so it won't splash on the floor while I adjust the water temp. I was honestly expecting more pressure than I got from all the positive feed back on them. (RV is hooked up to water with a 45 psi regulator.) I got the chrome finish from camping world and it didn't come with a shut off valve but I called and they sent one right over free of charge. It does splash more than a regular shower head but I guess that gives the allusion of more pressure. All in all I still use it but kept my old shower head just incase.
Try getting in the shower, closing the door behind you, taking the shower head out of the holder, then turning the water on while pointing the shower head down at the ground. Now adjust the water temperature.
It's not an illusion...this shower head rinses shampoo out of my hair faster than a residential shower head. Also, we can take an entire shower AND rinse down the shower walls and still not run out of hot water. It sounds as though you don't really have a need for a shower head like this.
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
Old 05-26-2014, 08:26 PM   #53
I thought post#(24) explained it well! Youroo!!
Old 05-26-2014, 08:54 PM   #54
Toy-aholic
I will second this for sure....I do the exact same with same results
Old 05-26-2014, 09:38 PM   #55
Used ours for the first time this weekend. Why did I wait so long to get it?? It is much better! Only complaint is we have a shower curtain and now with the added force of the new shower head it launches the water towards the back and it can leak onto the floor as another poster suggested. Looking for a new shower curtain now because the better pressure is worth it!
Kf4mnc is offline   Reply With Quote
Old 05-26-2014, 10:08 PM   #56
sunnygirl01's Avatar
Just ordered one from one of the amazon links you guys provided. I cannot wait to get it! I have thick, long hair and I usually go to the campground showers because it takes forever in the camper to wash and rinse my hair. I think the one I ordered has a shut off valve. Let's hope so because I think we only have a 4 gal tank in our camper! Lol!
Sent from my XT1055 using Tapatalk
Steve and Brandi & our "Pit" crew Bella
sunnygirl01 is offline   Reply With Quote
Old 05-26-2014, 10:17 PM   #57
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
If it comes in the original packaging it should include the shutoff valve.
My daughter has one in "her" bathroom and says it's the best thing ever, we had to get a new one for the trailer
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-28-2014, 09:54 AM   #58
BamaBob's Avatar
We got a separate cut off valve from amazon and mounted it on the hose attachment at the faucet. MUCH easier to control water flow.
Had some "guests" camping with us over the holiday weekend...their 2 observations were:
1. The shower was as good - maybe better than the one they had at home!
2. The 8289WS air bed was almost like sleeping on a sleep-number bed!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-24-2014, 06:20 PM   #59
New to the forum so hope this question is not off topic.
My Cedar Creek fifth wheel has coppertoned plumbing i.e. faucets, shower head and hose etc. I have really low shower pressure in the shower and would like to change the head for an "Air water fusion" type. Does anyone know if a copper tone replacement is available.
donpark is offline   Reply With Quote
Old 06-24-2014, 08:59 PM   #60
BamaBob's Avatar
Don,
First off Welcome to the Forums from Huntsville, AL!
Not sure if this will work for you but IMHO even if it does not match, this shower rocks - just like being home!
http://smile.amazon.com/Oxygenics-26...cs+shower+head
show, shower
