Old 06-15-2015, 07:00 PM   #1
deebarjay's Avatar
shurflo accumulator installation
I have a 2015 rockwood minilite 2309s. my water pump is a 4008-101-A65 with shutoff pressure of 55psi. the factory [in mexico] pre charges the bladder to 30 psi.....called shurflo in cali. they say for this pump the pre charge must be 40 psi..so that's what I did. positioning the accum. was something else...I had to remove the pump from the sidewall baseplate and move the baseplate down til it bottomed out on the floor and also position it more inboard.bought Tee and stainless clamps at Ace for $6.00.
deebarjay is offline   Reply With Quote
Old 06-19-2015, 08:08 AM   #2
phf
Did you install it to make the system less noisy? If so, has it worked?
phf is offline   Reply With Quote
Old 06-19-2015, 12:40 PM   #3
deebarjay's Avatar
gotta have a good shower!!
not for noise....pump is not heard in my rig....installed for steady pressure...water pulsed in my last rig during shower...this and the ecocamel showerhead gives the perfect shower.
