Old 12-15-2013, 09:25 PM   #1
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Sink cover/cutting board
Hey y'all..... ok so we bought this new 2014 Work & Play 25 ULA.
It has a large double sink (60/40). It has a single LARGE sink cover/cutting board made out of that 1/4" thick white plastic. Its a bearn to store and there are times when we would like to have TWO covers and not one big one.
So my question is... has anyone cut their single cutting board in half (60/40)... and if so how did you cut it in half? What type of tool, saw, jig saw, dremel, etc. Did you round the inside corners or leave them sharp to fit together better?
Any help on this topic is greatly appreciated.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 12-15-2013, 09:50 PM   #2
mTn_biKer65's Avatar
We're in the same boat as well but hadn't considered cutting the existing cover but now ya got me thinking. We had been looking for 2 existing FR sink covers to replace the large single cover. I'm sure they're out there.
I have yet to find a convenient place to store the large cover for travel.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 12-15-2013, 09:54 PM   #3
jtstromsburg's Avatar
I'd find a friend or contractor with a table saw and use that. Then either router or plane the edges to slightly round them.
Should be fine
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 12-15-2013, 09:57 PM   #4
Would put a veneer blade in a table saw and use a rip fence to guide and just rip it in two. Hand sand or file the sharp edge to remove the burrs.
Old 12-15-2013, 10:02 PM   #5
itch'n to road trip
campnqueen's Avatar
Mtn Biker65...face I am tooo cheap to go buy ANOTHER set of cutting boards to fit the sinks. I just hate wasting what we already have.
Old Coot... thank for the suggestion. We do have a VERY OLD table saw... dont know if it still works. I will have to look into getting a veneer blade.
Jasper Ga.
Old 12-16-2013, 07:18 PM   #6
1surveyor's Avatar
if you are talking about the solid surface sink covers that match your countertops , you can cut them with a table saw or skil saw or router and then just take a palm sander and smooth them up and yes i would roll the edges a little bit so it does not cut anyone .
Good luck it's not that hard to do
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
1surveyor is offline   Reply With Quote
Old 12-16-2013, 08:19 PM   #7
Here is a bit more on cutting: The solid surface countertop can be cut using the circular saw. It's highly recommended that the cutting tool is made from carbide and has a minimum of 40 teeth, to ensure a smooth and accurate edge. The saw should be slowly run along the straight edge to help avoid the build-up of heat. Excessive heat will scorch the surface of the countertop and ultimately ruin the appearance of it.
2012WhiteSolera is offline   Reply With Quote
Old 12-19-2013, 10:07 PM   #8
miatared's Avatar
We cut ours in two. Love it, gives us a bit more counter space while allowing use of water. I used my portable circular saw.
Sent from my Nexus 4 using Forest River Forums mobile app
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 12-19-2013, 11:32 PM   #9
Iwannacamp's Avatar
Search on eBay for sink covers. I think you will be surprised.
2017 Puma 297RLSS
Old 12-20-2013, 10:31 AM   #10
Dave_Monica's Avatar
Use the plastic sink cover as a pattern and cut a purchased wood cutting board to fit.
Dave
Name:	cutting board 1.jpg
Old 12-22-2013, 09:44 PM   #11
dj3spots's Avatar
I have stored my sink cover and my stove cover(flat board, as a cover didn't come with stove) under the mattress on the bed. Also have stored them under the seat cushions on the couch. So far they ride well in either place
dj3spots is offline   Reply With Quote
Old 12-23-2013, 06:48 PM   #12
Walke's Avatar
Yes, cut mine in half with my table saw, 60 tooth blade. Smoothed the edges and stained. Cut half circle "finger holes" in the middle with my Dewalt Scroll Saw. I didn't take any pictures, the unit is now in storage. Worked great !
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 12-23-2013, 09:52 PM   #13
Dave
I like the way you think!
Sargent's Fox Hole is offline   Reply With Quote
Old 12-23-2013, 10:33 PM   #14
sdelam's Avatar
I used a jig saw and sand paper.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 12-23-2013, 10:40 PM   #15
Ford Idaho's Avatar
The sink cover/cutting board is a two piece deal that we do not use.
Bought some cutting sheets at Target, light, easy to clean and when they get sliced up they can go in the recycle bin.
Old 12-23-2013, 10:48 PM   #16
Capt. Mike's Avatar
We haven't cut ours, but we don't use it that much because it covers both sides of the sink, thus eliminating the possibility of using the sink while the cover is in place. I'll have to look into cutting it. It also doesn't ride on the sink, so we store ours under the couch.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 12-27-2013, 04:19 PM   #17
okiedragster's Avatar
i had the same problem, but i didnt have any sink covers at all with our Lacrosse but i didnt want to cover both sinks with 1 cover either ..so i went a local restaurant/cooking supply store and bought a large plastic cutting board (aprox. $25.00) that was big enough to cover both sides and cut each one to fit each sink seperate..just made cardboard templates and transfered it to the cutting board..
oh just a tip.. i marked mine on the back "for cutting only" so the top would always look new
oh p.s. the sink company wanted $80.00 plus shipping and really coudnt tell me which ones i had, so i would have been taking a chance on it not fitting and sending it back...
https://www.forestriverforums.com/attachments/signaturepics/sigpic51597_1.gif.pagespeed.ce.qvvx73TjQp.gif
okiedragster is offline   Reply With Quote
Old 12-28-2013, 08:48 PM   #18
Phat Phrog Stunt Crew
elind's Avatar
When I was Goshen last summer I ask about the split sink covers. Brandon York chased down some info for my Primetime LaCrosse and this is what he came up with for me. Maybe Glenn has a line on other covers.
Hello, It was very nice to speak with you yesterday. Here is the gentlemen's number on the sink cover.
Glenn Bruce Cell# (574) 596-7755.
Part #
18-KC09ED-L = Left side Sink Cover $24.00 ea.
18-KC09ED-R = Right Side Sink Cover $20.00 ea.
Shipping = $15.00 to anywhere in the U.S.
__________________________________________________ _
Total w/ Shipping $59.00
Thank You,
Brandon York
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-29-2014, 04:47 PM   #19
Jimsue's Avatar
Am looking for the same mod for our Roo 21RS...would like to know source for cover stock so I can fabricate my own...
Thanks for any leads...
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 04-29-2014, 05:30 PM   #20
Hey Jim, i found a very large cutting board at a commercial restaurant/cooking supply store place here in town. they had different colors like brown, black and off white i did mine in white because i couldnt find a solid piece that was big enough to cut 2 covers outta one piece..there was quite a few to choose from..i went back later and bought another one and cut it to go behind my stove to protect the wall from slpatter and i use it outside to cut on also...hope this helps..steve
cover
