Old 05-28-2014, 12:03 AM   #1
Sirius Satellite Radio Antenna Mod
Hello Out There!
This is my first mod that I've documented on my Wildwood T23BHLE, and was so pleased with the results I had to start a thread with the details.
We don't have a TV in our TT, but we do frequently use our Sirius Satellite Radio. I would stick the boom box under the awning and hope it would get a clear signal, etc etc... Well my antenna $*!#-the-bed and I was forced to start hunting for another antenna. Worried that the new one would suffer the same demise I thought about mounting a home antenna to the top of the TT to get a signal and not have to worry about aiming. I came up with the idea of using the existing Winegard antenna mast to attach the home antenna. Did some research and some people attach WiFi antenna without much hassle, so I figured I would give it a try.
I started by taking a better look at the Winegard to see how exactly I would mount it, and found that everything is plastic. No worries, as is the Satellite antenna. I had a look at where the Winegard mounts to the mast, and found a factory hole that looked like a good spot to try... Success! Found a bolt, lock-nut, and washers. BAM! Done.
Mounted antenna back on the mast and plugged the RG-6 cable into the Satellite radio antenna. Went inside the TT and removed the Winegard booster from the wall and disconnected the RG-6 cables. Plugged in the RG-6 to SMB cable supplied with the Satellite antenna, and BOOM! Works like a charm. I get full satellite reception with 3 bars of terrestrial reception with the mast down, and with the mast up I get full satellite and 7 bars of terrestrial reception.
Next step will be to disable the Winegard booster, but keep the cigarette lighter plug working, and to add a splitter at the outside cable plug to route a cable to the awning side of the TT with a cigarette lighter plug for power when not plugged in.
Fun fun!
Thanks for looking.
ID:	53513   Click image for larger version
ID:	53514   Click image for larger version
ID:	53515   Click image for larger version
ID:	53516   Click image for larger version
Ozzmosis is offline   Reply With Quote
antenna, radio, satellite, modifications
