Old 11-15-2016, 06:22 PM   #1
B D HOWie's Avatar
SiriusXM antenna install
Maybe this will help others.
Just installed a SiriusXM unit with my new Kenwood DDX374BT. I did not want to put holes through the roof. I placed the SiriusXM antenna in the roof air vent. It is under both the air vent and the MaxxAir cover.
Name:	ImageUploadedByForest River Forums1479251954.628596.jpg
Name:	ImageUploadedByForest River Forums1479251982.048360.jpg
Name:	ImageUploadedByForest River Forums1479251999.237312.jpg
It is held in place with the magnet antenna sitting on top of the metal brace of the air vent.
I used wall cable channel to hide the wiring.
Name:	ImageUploadedByForest River Forums1479252039.682885.jpg
The reception is fine from under these plastic covers.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 11-15-2016, 07:35 PM   #2
Failure is my business
2Evil4U's Avatar
Interesting. I've been procrastinating permanently installing mine. I'm thinking about mounting it to the TV antenna and running the cable along the same path. I'm just being lazy about having to pull the wire as I don't intend to open the ceiling. I like this idea.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 11-16-2016, 08:11 AM   #3
I drilled a small hole through the floor in the cabinet below my tv/stereo and ran the antenna to the tongue of the trailer. Antenna is a magnet mount and has worked perfectly. I do not have a belly pan on my trailer, so it was easy to install and seal up the hole on the top and bottom sides.
Miller303KDS is offline   Reply With Quote
Old 11-17-2016, 08:08 PM   #4
nowait's Avatar
I used small an XM radio antenna that they provide for your car (1"X1"). It has a very small diameter wire that I ran out through the window hinge.
2008 Silverado EXtCab 6.0 Vortex Max
2010 Forest River Surveyor SV-294
Equalizer 1000 WD/SC hitch
Prodigy Brake Controller
nowait is offline   Reply With Quote
Old 11-19-2016, 10:34 AM   #5
I have installed several and another good location is on top of the fridge vent cover. You can then run wiring down the cavity.
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
Old 07-11-2017, 07:59 AM   #6
B D HOWie's Avatar
Update
I installed Vortex fan units. I was not comfortable with only the magnet securing the antenna above the fan so I added Velcro and secured it to the top of the fan frame body.
Sorry, I did not think to take pics during the upgrade. The Vortex are an easy install because it is all done from the interior.
Paul
Paul
Old 10-24-2017, 12:55 PM   #7
B D HOWie's Avatar
I updated this installation when I upgraded to LED lighting. Put the ceiling power run in the race between the light and the vent.
Paul
Paul
Old 10-24-2017, 09:13 PM   #8
B D HOWie's Avatar
Also put the SiriusXM cable in the ceiling.
Paul
Old 10-25-2017, 07:47 PM   #9
Thurman's Avatar
American ingenuity at it's best. I have had thoughts about adding Sirius/XM to the TT as we listen to music much more than watching TV. But, the pricing of Sirius/XM has gone up so much in the last three (3) years that I have to think more than twice about it, and I get a GM retiree discount.
Thurman is offline   Reply With Quote
Old 10-26-2017, 08:09 AM   #10
B D HOWie's Avatar
Here is a pic of the antenna Velcro'd to the top of the fan.
Antenna wire run thru ceiling comes out at the ceiling light then into the surface mount cable chase on the wall (see pic in post #7).
Paul
Paul
Old 07-08-2018, 09:48 PM   #11
I ran mine from the radio under the floor matting pulled the door step through a hole up to the roof. Glued the antenna to the roof. Click image for larger version
ID:	178782Click image for larger version
ID:	178783Click image for larger version
ccarlock is offline   Reply With Quote
Old 07-08-2018, 10:09 PM   #12
Nurek's Avatar
FYI: I'm in Canada and been an SXM sub for 6 years and have never paid more than $130CAD per year for both the car and streaming. They wanted $330 for the next year. If you are paying more than that, you are being hosed.
Never talk to the gatekeeper- first person who takes your call. Ask to be transferred to retention/loyalty. If they ask what it is in relation to, just say "nothing you can help me with".
Stick to your guns and never settle for their first offer.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 07-08-2018, 10:13 PM   #13
Nurek's Avatar
I ran the antenna wire out through the LP port and up to the roof at the rear end of the awning. The magnetic antenna is secured to a small round piece of galvanized steel that I siliconed to the roof. Antenna is removable in case of no reception issues.
antenna
