Old 02-25-2014, 09:55 PM   #1
OL Creeker's Avatar
Skylight and radiant heat
I reduced the heat allowed I to the bathroom through the skylight with a simple, cheap, easy mod. Take yourself to WM, look in the crafts section for the plastic, needlepoint backing. There are three to a pack, each is about 12" X 24", $3.00. Cut one to size. We used six small pieces of double stick tape. But! We had to stitch each one along one edge of itself - it doesn't adhere well to the plastic. This mod greatly reduced the heat. Yet allows the light. Sort of like an arbor!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 02-26-2014, 06:25 AM   #2
cpaulsen's Avatar
Good idea!! I have already used Reflectix with velco.
cpaulsen is offline   Reply With Quote
Old 02-26-2014, 07:15 AM   #3
I made a perforated alum cover for the outside to keep the heat from getting into the inside. It has a solid alum panel in the top for cleanout which further blocks the heat. Used Eternabond tape to attach it to the roof without drilling any holes.
ID:	46859   Click image for larger version
Name:	Skylight Cover with cleanout panel.jpg
ID:	46860   Click image for larger version
Old 02-26-2014, 02:10 PM   #4
BigTJohn's Avatar
I just used a two layer of window screen taped in place on the inner bubble (yes, I removed the 87 screws holding it is place, taped the screen on it and replaced it) it is flat on the inside portion so very easy to work with. $0.0 as I already had the excess screen from redoing a couple of doors.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 02-26-2014, 02:25 PM   #5
golfmedik's Avatar
I simply cleaned the skylight and painted it with 2-3 coats of Krylon Gloss White paint. No heatm all the light and cost me under $4.
Monty
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 02-27-2014, 10:11 PM   #6
10x
Monty
Great idea, how is it holding up?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 02-28-2014, 12:44 PM   #7
golfmedik's Avatar
After two years it still looks like I just sprayed it!
Old 02-28-2014, 04:16 PM   #8
10x
Did you use the the Krylon for plastic or just the normal enamel paint?
2014 XLR 27 HFS
Old 02-28-2014, 04:42 PM   #9
golfmedik's Avatar
Krylon for plastic...
Sent from my SCH-I545 using Forest River Forums mobile app
Old 03-04-2014, 06:22 PM   #10
2014 327 Lacrosse
We took the inside dome off- about 4 screws and slipped some reflextic (silver bubble insulated materials found at Home Depot or similar store) and then replaced the inside dome. Now with this material between the outside dome and the inside- looks great and will save us turning on the second AC this summer hopefully.
Pipers Family is offline   Reply With Quote
light
