Old 01-25-2015, 04:26 PM   #1
sliding Pantry shelf?
I have a 2002 Salem 29RLSS, just bought it, The shelves in the pantry are narrow and deep I would like to install something that canned goods would sit on or in that would pull out allowing you to more easily see things in the back. Anybody know of such a thing?
J W Bowman is offline   Reply With Quote
Old 01-25-2015, 05:08 PM   #2
A simple google for sliding cabinet shelf will find a lot of options. I'm not promoting HomeDepot over any other source but you can find examples HERE. If none fit, consider disassembling one and cutting down the width.
In your case it's probably a good choice but be aware you'll lose a percentage of the width of the cabinet to the clearance required by the hardware. Unless you have European-style cabinets (I've never seen them on RVs) the face frame is narrower than the cabinet itself. Plus, the interior dimension of whatever shelf you install will be smaller still. If you fit it right you can maximize the available space but there will still be some loss. That might be exceeded by the space gained at the back of the cabinet that you otherwise wouldn't use.
Be sure to secure it from rolling out during RV movement. The cabinet door latch might do that but also might not be designed to resist the pressure of a rolling shelf.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 01-25-2015, 05:24 PM   #3
fonzie's Avatar
Here's one thread on subject....
2011 378TS Pantry Modification
You can do a search above for "pantry mod"
Fonzie
Old 01-25-2015, 05:41 PM   #4
HappyCamper77's Avatar
IKEA.
Ontario, Canada
2014 Dodge Ram 1500 5.7
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
HappyCamper77 is offline   Reply With Quote
Old 01-25-2015, 06:33 PM   #5
caper's Avatar
I purchased several of this style drawer slide at HD. Only have to add ends and bottom. Found they gave me more room in the closet because the sides are mad of metal you save almost 1". Inside closet I installed thin board (shims) to build up sides to install inside brackets. I used construction adhesive to stick shims to inside then screwed the brackets through the shims (gave it more strength to hold screws). Have used this for past 4 years and not had a problem (one shelf holds canned goods). Because drawers are behind door did not worry about finishing end boards. The trailer is asleep for the winter so I cannot get pictures.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-17-2015, 09:49 PM   #6
Pull out pantry
I built a full extension slide out pantry in a wardrobe of my Wildwood. Used 1/2" and 3/4" baltic birch plywood with some maple. Used rabbet and dado joints and used glue only for assembly. Took a while but the results are a very usable pantry that gained a lot of storage space.
Ozzmosis is offline   Reply With Quote
Old 02-17-2015, 09:50 PM   #7
Dado joints
Old 02-17-2015, 09:52 PM   #8
Pantry closed to show clearance
Old 02-18-2015, 04:15 PM   #9
mike618's Avatar
That is a great looking pantry Ozzmosis
Mike and Mary
2014 Flagstaff 831RKBSS
2001 Suburban 2500/6.0
1999 Chevy 2500/6.0
mike618 is offline   Reply With Quote
Old 02-18-2015, 06:59 PM   #10
Thanks!
Quite overkill, but it'll survive longer than the trailer
