Old 08-13-2018, 01:46 PM   #91
Originally Posted by KyDan View Post
I believe the slim shade comes with a template printed on the inside of the box so you can cut a window opening if you need to.
Thank you Sir
tyler811 is offline   Reply With Quote
Old 04-06-2019, 04:54 PM   #92
So we finally got around to trying to figure out the the best way to open and close the window without opening the door. That proved to be a pain in backside and let in tons of bugs.
We bought a dog door which looked too bulky and obstructed our view. We bought screen and threw around the around the idea of Velcro or magnets.
Then the wife bought one of those magic screen door things. She came up with the idea just removing the original screen in the door and putting the magic screen in it's place. I left it a little loose so it would close the gap in the middle.
We will replace the lower half with a solid section left over do the whole matches.Click image for larger version
ID:	201010Click image for larger version
ID:	201011Click image for larger version
Old 04-06-2019, 05:02 PM   #93
Scubanut's Avatar
We will replace the lower half with a solid section left over do the whole matches.Attachment 201010Attachment 201011Attachment 201012
Wow, love that idea. Now you solved my biggest gripe about the window shade.
Scubanut is offline   Reply With Quote
Old 04-06-2019, 05:22 PM   #94
As an added bonus you can pass your favorite beverage through the screen window without opening the door.
Old 04-06-2019, 05:22 PM   #95
Tigger1's Avatar
Slim Shade
It was a nice sunny warm day today so I decided to install the slim shade. Like others have experienced it only took about 30 minutes. I installed the shade from the bottom up and it works fine. Just sitting in our driveway we like the ability to see thru the door glass.
I was not able to get a tight seal on the top exterior plastic frame as you can see in the photo. I tried some silicone caulk but it didnít adhere and I removed as much as I could. I just ordered a tube of Proflex Rv Clear and will put that on. Otherwise we like the product.
2018 Rockwood Mini Lite 2104S
2003 Toyota Sequoia SR5
2014 Jayco JayFeather x17z Hybrid (2014 - 2017)
Tigger1 is offline   Reply With Quote
Old 04-07-2019, 07:31 AM   #96
Great idea! Would it be asking too much to post more pics of the whole door? I have one of those screens that I bought years ago for a travel trailer I built and never installed and am going to do this upgrade.
Say what you mean, mean what you say.
Reeac is offline   Reply With Quote
Old 04-07-2019, 10:48 AM   #97
Here is a picture of the full door. If you would another others just let me know.Click image for larger version
Old 04-07-2019, 09:56 PM   #98
Thanks for the pic but what I wanted to see was how you attached the screen from the inside, mainly the bottom and how far down it goes and is attached at the bottom.
Old 04-08-2019, 06:54 AM   #99
The bottom of the door we have done yet. It is still the factory screen that came with the door.
We did not attached the screen from the inside.
1. We removed the door from the frame
2. Placed the door on a two saw horses
3. Removed the rubber rope from the top section of screen on the door.
4. Placed the full magic screen on top of the door
5. We placed it with 3 inches over lap on the sides, top and bottom.
6. We then cut off the remainder of the magic screen leaving the 3 inches overlap all around. Thus giving us room to maneuver the magic screen into place.
8. We left 4 magnets in place to provide a better seal.
9. I started on the handle side of the door with the rubber rope from the bottom of the opening to the top.
10. If you look at the screen there dark sections (lines) of screen going vertical on the screen. I used this as a guide to get the screen fairly straight.
11. I left about a 16th of an inch of play on each side is the screen would close tightly.
12. I ran the rubber rope all around the opening into the guides and cut off the remaining rope.
13. Using a new blade in a box cutter, I cut off the remaining 3 inches of screen at the rubber rope.
I can reach my hand through the screen and open/close the shade on the window. The magnets close keeping the bugs
Old 05-09-2019, 02:59 PM   #100
2-J's's Avatar
Has anyone installed this Slim Shade where the inside of the window in your door does not have screws holding it in?
Ours doesn't have any screws and we were wondering if there is a trick to prying it off with out damaging the window or the door.
Thanks!
John & Janet
2019 Surveyor 267rbss - 2017 Ford F250 Superduty
New adventures in RV'ing started 2017....
2017-54, 2018-84, 2019 planned 89
2-J's is offline   Reply With Quote
door, window
