Old 05-13-2019, 12:39 PM   #101
I haven’t come across any that didn’t have screws. Try posting pics to better understand what you have.
Say what you mean, mean what you say.
Reeac is offline   Reply With Quote
Old 05-15-2019, 12:51 PM   #102
Originally Posted by 2-J's View Post
Has anyone installed this Slim Shade where the inside of the window in your door does not have screws holding it in?
Ours doesn't have any screws and we were wondering if there is a trick to prying it off with out damaging the window or the door.
Thanks!
I think it may snap together, you could take a putty knife and see if you can get it between the plastic and the door. Very gentle lift outward to see if the plastic frame releases. The frame itself may be split at the top or bottom. If it is then place the putty knife to either the left or right of the split.
tyler811 is offline   Reply With Quote
Old 05-15-2019, 07:59 PM   #103
david_reaves's Avatar
Originally Posted by Reeac View Post
Great idea! Would it be asking too much to post more pics of the whole door? I have one of those screens that I bought years ago for a travel trailer I built and never installed and am going to do this upgrade.
So, I'm thinking that the magnetic strips could also go on the cross-bar portion of the frame. If you do that, you could then put the magnetic strip down one side instead of the middle-- then open the screen diagonally. With the screen openings on the side, there'd be nothing to block the view out the window! The two sides and top would be in the screen channels, the bottom magnetic.
It would be something like the drawing below, but opening could be even closer to the edge.
david_reaves is offline   Reply With Quote
Old 05-15-2019, 08:15 PM   #104
Yes we thought about that but the shade opens best when grasped from the middle. We used to do it does not bother us. It is worths a try.
2023 3/4 ton Chevy Silverado Diesel
2024 Grand Surveyor BHXL 240. 400 watts solar, 2000 watts pure sine inverter, 30 amp controller and remote 2-100ah LiFeP04 in parallel
Old 12-25-2019, 07:50 PM   #105
With care, I pried out the old window, installed the new. Installing the new goes better, and safer, with extra hands.
grport is offline   Reply With Quote
Old 12-25-2019, 08:04 PM   #106
RBDTx's Avatar
There are special expensive wedges that insert in small spaces between the frame and the door around the entire frame. Looking for the link now.
https://store.lci1.com/window-keys-16-pack-429436.html
RBDTx
2020 Rockwood Mini Lite 2109s
2019 Toyota Tundra TRD Pro
RBDTx is offline   Reply With Quote
door, window
