Originally Posted by Reeac
Thanks for the pic but what I wanted to see was how you attached the screen from the inside, mainly the bottom and how far down it goes and is attached at the bottom.
The bottom of the door we have done yet. It is still the factory screen that came with the door.
We did not attached the screen from the inside.
1. We removed the door from the frame
2. Placed the door on a two saw horses
3. Removed the rubber rope from the top section of screen on the door.
4. Placed the full magic screen on top of the door
5. We placed it with 3 inches over lap on the sides, top and bottom.
6. We then cut off the remainder of the magic screen leaving the 3 inches overlap all around. Thus giving us room to maneuver the magic screen into place.
8. We left 4 magnets in place to provide a better seal.
9. I started on the handle side of the door with the rubber rope from the bottom of the opening to the top.
10. If you look at the screen there dark sections (lines) of screen going vertical on the screen. I used this as a guide to get the screen fairly straight.
11. I left about a 16th of an inch of play on each side is the screen would close tightly.
12. I ran the rubber rope all around the opening into the guides and cut off the remaining rope.
13. Using a new blade in a box cutter, I cut off the remaining 3 inches of screen at the rubber rope.
I can reach my hand through the screen and open/close the shade on the window. The magnets close keeping the bugs
