Old 03-22-2009, 05:29 PM   #1
Snap Grommets For Out Door Camping Carpets
Was at Walmart yesterday and came across this Item in the seasonal section. They are Sun Screen Fabric Snap Grommets. I was going to install the brass grommets in my out door carpet for the camp ground and use tent steaks to keep it from blowing on windy days. They are gray plastic and UV resistant and come in a package of ten pairs, one male and one female. I installed 12 Snap Grommets in less the 10 mins. Very easy to install and fit tight.... It dose say SUN SCREEN FABRIC but It works fantastic on indoor/outdoor carpet....Just thought I would pass it on.
ID:	1396   Click image for larger version
ID:	1397   Click image for larger version
Old 03-23-2009, 06:45 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
We added something similar to our patio rug and use the Presto Rug stakes. They are easy to drive in gravel and can be easily removed with a claw hammer. They especially worked well at the beach. Here's a link for them @ Camping World, but I believe we bought something similar at Walmart. I could be wrong though.
http://www.campingworld.com/shopping...g-stakes/37597
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-23-2009, 10:53 AM   #3
I bought tent steaks from Walmart, they look like the same ones you show but they have a removable orange tops, 4 pack for $2.00. I just need to add a flat washer on each one.
Old 03-23-2009, 11:39 AM   #4
Cyber Phrenologist
Radio's Avatar
So what do you cut the round hole with? Utility knife or whatever, or is there a special tool?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 03-23-2009, 11:45 AM   #5
cfsoistman's Avatar
I cheated. I used a 3/8" O/D Copper Coupling, heated it up and melted the hole through the carpet and sealed the edges in the process. That's a Refrigeration Size copper fitting. It stinks a bit and I cleaned it off with a wire wheel on my grinder after doing 2. This way I don't need to worry about it unravelling where the hole is cut through.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-23-2009, 12:15 PM   #6
No special tool, all I did was place the male part of the grommet under the carpet placed my thumb on top and used a utility knife to make small cuts in the carpet then pushed the male grommet though the hole then applied the female side on top and tapped it down with a hammer as the instruction call for.
