Old 06-26-2012, 07:19 PM   #1
kevnval's Avatar
Sofa /air bed storage drawer..
We have one of the sofas that converts to the air bed...a very nice design and quite comfortable in my opinion.
The problem is the storage drawer underneath....will not stay on the slides...slides have fallen apart....jams up...had the slides replaced once already by the dealer...fell apart again this weekend.We only store a few items in the drawer , minimal weight....
Has anyone had this problem? Have you modified it yet?...what did you do?
I'm thinking I may separate the drawer completley from the sofa...attach casters to it for easy movement .
What do you think.
2015 Sabre Silloutte Select 312 RKDS
2015 RAM 2500 CC 4x4 SXT 6.4l Hemi 3:73's
Former Michelin Tire Guy
kevnval is offline   Reply With Quote
Old 06-27-2012, 07:53 AM   #2
murry52's Avatar
Sounds like a manufacture defect ( Who ever built couch) Your dealer should be having a better look into this. Remember Squeaking Wheel gets attention Stay after the dealer to solve this.
murry52 is offline   Reply With Quote
Old 06-27-2012, 08:13 AM   #3
I'm thinking I may separate the drawer completely from the sofa...attach casters to it for easy movement .
What do you think.
I had the same problem with another trailer I had. I went to a local cabinet shop a purchased a pair heavy duty slides. I also had to shim behind the drawer slide ( the drawer component) to tighten them up as it was somewhat loose or sloppy, side to side. Also after opening the drawer with the slide fully extended. the slides have a tendency to open up on the ends. It seems like the factory slides will not handle the weight. In the meantime don't overload the drawer. I think the casters under the front of the drawer may be a good solution as well
Just my opinion,
Rick
grayfox is online now   Reply With Quote
Old 06-27-2012, 07:53 PM   #4
I made a wooden wedge that we install under the the drawer it is easy to install and works great.
cwocg is offline   Reply With Quote
Old 06-27-2012, 07:55 PM   #5
murry52's Avatar
Is the wood wedge permanent or does it have to be re installed at every use
Old 06-29-2012, 05:58 AM   #6
great white's Avatar
I'd call it a "defect".
No issues at all with my couch drawer and we store heavy stuff in it.
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
bed
