Forest River Forums
Sunline User Photos
Old 09-28-2011, 10:58 AM   #11
Willybgh's Avatar
Originally Posted by jimh
why would u want that? black system is closed, vent used for fill and drain.
If you look on the roof of your trailer, you should see a vent for your black tank. It needs to be vented for the gases that build up while decomposition is in progress.
TV: 2007 GMC 1500 Crew Cab 5.3L
Brake Controller: Tekonsha P3
Hitch: Equal-i-zer 4 point wd/sway control
Trailer: 2011 Grey Wolf 26RL 5700lb dry
In Past: 2008 Cikira 19 EXP hybrid
2008 Clipper 108st (pop-up)
Willybgh is offline   Reply With Quote
Old 09-28-2011, 05:04 PM   #12
jimh's Avatar
question was more of why u would want a fan on it? what would be the advantage over natural ventilation?
when u dump, u will actually be pulling against the air trying to go in. i don't see a problem with it, just no advantage.
now put that fan on one of the addict vents and u have something.
jimh is offline   Reply With Quote
Old 09-28-2011, 05:14 PM   #13
too fast turbo sled
f1100turbo's Avatar
Jim has got something there........ jim is implying that how would the fan draw any air when the system is closed or in other words where is the fan going to draw from ? Only way I see it is the fan can only draw when toilet is flushed. It would be like trying to suck air from a plastic pop bottle and until you put a hole in the bottom to draw air it virtually impossible .
correct ?
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 09-28-2011, 09:19 PM   #14
jimh's Avatar
that is what i'm seeing. there wouldn't be an air flow except while the flush valve was open. well there would be a flow after the sewer is dumped and before the sewer drain valve is closed.
don't see it as doing any harm just don't see the benefit. something like this could be put to better use.
Old 09-29-2011, 07:17 AM   #15
Lou Amadio
herk7769's Avatar
I am guessing the idea is to always have a "slight" vacuum (lower pressure) in the black tank so when you flush any gasses that have collected under the toilet seal will be sucked down and not allowed to enter the camper.
Not sure how effective it might be; how long it would last; or even if it would work as advertised. Save your money for beer.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 09-29-2011, 07:18 AM   #16
Willybgh's Avatar
Good point. Never thought about that. When Jim said closed system I thought he mention no vent either. My mistake.
Old 09-29-2011, 07:37 AM   #17
jimh's Avatar
if u've already got one, why not try it on one of those roof vents. there are several jacks up there that just ventilate the addict. i believe they are the same size as the sewer jack. may try putting it on one and see if it helps ur a/c next summer (may want that heat this winter).
benefit of it being solar is that it would be on when u need it the most.
i don't know how much space there is up there that isn't filled with insulation. there should be some.
if the space is full of insulation, it could be counter productive to force ventilation...u wouldn't want to disturb the dead air space.
» Online Users: 527
82 members and 445 guests
02 rockwood, 4bnabird, 4Jeeperz, 8261ss, backpacker3, Barnman1, Bearcat55, bfisher82, bob7794, bouldercamper, buzzmonster, campfun, CampinQueen, carsonizik3, ClampNfish, cstover, depo, djorgensen3, dlmurray51, DonCath25ds, DonG, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, Freds342, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, Kentdb1, kgmat, KKapa, lindy, Mad4sax, Marc73, Mike G, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, NO3putt, Pa-cj5, patov6, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, RichN, RickV, Riva, Roamin Ovum, rschroe, Rsgtivr6, Rugged Brown, Russ, ryoucrazey, seatosea, ses, shiggs, Sparkbark, SpringerPop, Stevea1956, tfennell81, tgarner2000, tonybab, transamz9, troyt, UPGRADER, vp22er, Walke, wbdvt, Whiskeyjack, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
