Old 10-25-2007, 10:27 AM   #1
solar panel to keep battery charged
Has anyone added a solar panel to keep their battery charged?
Im thinking of doing this but am not sure what size panel to use. I would like to add one that will keep the battery charged all the time whether im using the TT or not.
Thanks.........
hoorders is offline   Reply With Quote
Old 10-25-2007, 11:41 AM   #2
2manytoyz's Avatar
I'm using solar panels at home, so have a little experience in this arena.
Your location will have an impact on how well a solar panel works, as well as its view of the Southern sky, time of year, angle of the panel, etc.
Also things like detectors eat battery power day & night, whether on or off (never really off). Suggest installing a battery disconnect switch.
If your batteries are already charged, you can get away with a smaller panel. Some claim they do fine with a 5 Watt panel ($39 on sale at Harbor Freight), but I'd recommend a 15 Watt panel ($79 on sale at Northern Tool).
Power (Watts) = I (Current in Amps) x E (Volts). I=P/E, current for the 5 Watt panel is 5/12, or 0.42 Amps during the peak of the day in ideal conditions. That's not much! The 15 Watt panel is 15/12, or 1.25 Amps, a safe trickle charge amount.
You only get usuable sun during a 4-5 hour stretch, depending on your location. A 15 Watt panel will keep your battery topped up. If you decide to add more panels to recharge, not just maintain your battery(s), you should invest in a solar controller too. Also available at Northern Tool for a few more sheckles.
Here's what the 15 Watt panel looks like:
Note, the store price for this panel is $99. Print out the online price of $79, and they will honor it in the store.
Robert & Dawn
2007 Rockwood 2502
2010 F-150 FX4
Equalizer Hitch -w- 1000# bars
Yamaha EF2400iS generator
http://www.2manytoyz.com/
2manytoyz is offline   Reply With Quote
Old 10-25-2007, 03:55 PM   #3
steveqvs's Avatar
Disconnect switch? Could you describe how to install and what it looks like. We have a new TT and I just unscrewed the ground to keep from discharging. It has a wingnut so its pretty easy but a disconnect switch would be sweet!
Steve
steveqvs is offline   Reply With Quote
Old 10-26-2007, 09:17 AM   #4
2manytoyz's Avatar
You can find these in various flavors, but here's a cheap style you can find at places like Walmart:
Rotate the knob, it disconnects the battery. No tools needed. Turn the knob the other way to reconnect the battery.
Robert & Dawn
2007 Rockwood 2502
2010 F-150 FX4
battery, solar
