Old 06-20-2015, 11:47 AM   #31
opfor2's Avatar
Here is another way to mount and run the cable for the solar panels. Also, a lot of solar install equipment can be purchased off of E-bay at very reasonable prices as long as you know what the retail price is and shop around. For instance, AM Solar sells 4 "Z" mounting brackets for $ 40.00, I got 8 "Z" brackets on E-bay for $18.00 and they were stainless steel. So shop around and take your time.
Dan..
https://youtu.be/oqfIjfF5eGQ
2004 Sierra Sport Toy Hauler CSET21SP
opfor2 is offline   Reply With Quote
Old 06-21-2015, 09:13 AM   #32
They are running the cable down the refrigerator vent located on the roof. Our Flagstaff Classic refrigerator vent is on the side, below the awning. What I ended up doing was going down the black tank vent. I drilled a hole in the pipe and pulled it out of the vent, resealing the hole back up with silicone. Once there I installed the regulator and in the storage area, pulled the wire across and drilled another hole in the battery area and attached it to the batteries. Works just fine.
Pursell is offline   Reply With Quote
solar
