Old 04-07-2015, 10:40 PM   #1
Solar panels
2014 Salem 30QBSS Solar panel install
Doug C
2006 Ford F-150 / 5.4 / 4x4 / Crew Cab / Tow Package /Blue-Ox 1000
2014 Salem 30QBSS
Doug_C is offline   Reply With Quote
Old 04-07-2015, 10:47 PM   #2
Some pics
ID:	73494   Click image for larger version
ID:	73495   Click image for larger version
ID:	73496   Click image for larger version
Doug C
2014 Salem 30QBSS
Old 04-08-2015, 06:09 AM   #3
RPAspey's Avatar
Looks good. You'll love the freedom of solar. Its an expensive mod, but you'll agree worth every dime.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is online now   Reply With Quote
Old 04-12-2015, 05:17 PM   #4
wwalker2984's Avatar
Here is what I did I got semi flexible solar panels and glue them to the roof of my 2015 wildcat and didn't have to drill holesClick image for larger version
Name:	ImageUploadedByForest River Forums1428876988.440193.jpg
ID:	74019Click image for larger version
Name:	ImageUploadedByForest River Forums1428877029.358648.jpg
wwalker2984 is offline   Reply With Quote
Old 04-16-2015, 10:17 AM   #5
How are the glued on panels holding up? I used the same panels but I also screwed them down for fear that the dicor wouldn't hold them completely over time.
wickedwyrm is offline   Reply With Quote
Old 04-16-2015, 01:58 PM   #6
Well so far so good I glued under the panels and all a round the edge of them I used the same stuff as they put around the vent screws I just didn't want to put holes in my brand-new trailer
Sent from my IPhone
Old 04-16-2015, 02:18 PM   #7
vinmaker's Avatar
I was thinking of buying these. $137 seemed like a fair price.
250w Monocrystalline Solar Panel - Buy 250w Mono Crystalline Solar Panel Product on Alibaba.com
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-16-2015, 04:16 PM   #8
Don't forget the cables and control box
Doug C
2014 Salem 30QBSS
Old 04-22-2015, 02:23 PM   #9
What kind of screws and mounts are people using for solar panels? I have the panels and my house is on solar so I am familiar with everything except for putting holes in the roof of my trailer. Do I need to find a support member or is the roof material sufficient? regular self tapping (tek) screws ok? How long?
Any input would be great, I am just a bit apprehensive about the drilling part. Thanks!
stinkmonkey is offline   Reply With Quote
Old 04-22-2015, 06:23 PM   #10
Salem roof is 3/8" thick, designed to walk on as we may know. I mounted my solar panels by first laying them in place, then I marked all the holes 8 holes per panel...2 per corner then I drilled 1/8" pilot holes in the marks..... then I use stainless steel 3/4" #10 self-tapping screws. I used sealant in the pilot holes, underneath the brackets, screwed the brakets down and then applied self leveling LAP sealant over top of the brackets pretty watertight. The instructions recommended using wellnuts which are somewhat difficult to find around here for some reason. My units are pretty secure and do not believe I will have any water leaks.
Doug C
2014 Salem 30QBSS
solar
