Some of you with units with just one outdoor speaker may have discovered the following:
The hillbilly that wired it to our Furrion head unit (which only has L and R outputs for speakers) decided that to 'control' output from two inside speakers and the one outside speaker, 'hey, let's wire the outside speaker to the R channel, and BOTH inside speakers to the L channel!' Hyunk, hyuk, yuk! This way you have to adjust the balance to control speaker volume.
Unfortunately same hillbilly never heard of stereo (been around a while now), so you won't have stereo inside (even with two speakers), and you'll just have to miss out whatever sounds were supposed to come out the R channel, (unless you are outside), in which case you won't hear what is supposed to be coming over the L channel. Brilliant!
I will be rewiring properly in the Spring, with a push button wall mount speaker selector for inside/outside, and having to figure out how to run another pair of speaker wires to the outside speaker, which I plan on replacing with this:
https://www.crutchfield.com/p_917FS4...yABEgLgm_D_BwE
I will have to buy spacer to flush mount it. So all in all, I will have to spend 225 bucks plus 10 bucks for speaker selector to make the stereo work properly, the way Rockwood should have done at the factory. BTW, this speaker accepts both left and right channel speaker wires. Hopefully mounting it in place of old speaker and running extra wire to it is not too frustrating. Brand new Rockwood too. 2019 model.
