07-07-2018, 09:40 AM
Graywolf 27 rr toyhauler
Speaker replacement on outside
The speakers on my 27ft toyhauler are terrible and advice on speaker replacment
07-07-2018, 09:46 AM
If your are replacing the outside speakers make sure they are waterproof and of the same impedance as the inside speakers (impedance may not be the correct term)
Retired Navy
2016 Flagstaff 26 FKWS
07-07-2018, 09:51 AM
Impedance is correct or more commonly known as ohm value.
+1 on waterproof, marine speakers.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
07-07-2018, 10:11 AM
How deep is the speakers hole does it matter. The sound out of the stock speakers are bad hope it's not the furion head unit
07-24-2018, 03:21 PM
Outside speakers are too weak.
My exterior speakers are pitiful. Anyone else deal with the fact that the outside speakers barely put out sound, and when you turn on the interior speakers, they are way too loud inside, but outside they barely put out sound. We have to use either outside only and turn way up, or inside only. We can't use them together.
07-24-2018, 03:59 PM
Kasual Kamper
+1
Can't understand why the relative volume is different.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
07-24-2018, 04:05 PM
Yeah, we were wired weirdly anyway. The stereo system was designed for 3 speakers setups. A, B and C. A was just the speaker inside front. B was just inside rear. C was both outside.
I took the system out and wired the inside speakers both to A left and right. That got me stereo sound back inside. B is now unused, and C is outside both. Still weak outside.
I even wired the outside to B to see and they still suck.
I think the outside speakers are a completely different Ohm rating than the interior.
07-24-2018, 04:11 PM
When I called patrick industries they said it was the mismatch of impedance on the outside speakers the caused the problem in my rig. I don't listen outside so it hasn't bothered me.
Retired Navy
07-24-2018, 04:33 PM
I'm no noisy pain neighbor. I hate people who blast their music and invade my peace, but I like to have something on real low right near the camper at times.
I think I'm going to change all four speakers to an all weather matched set.
07-24-2018, 04:35 PM
Well is there any replacement for them west marine
07-24-2018, 05:14 PM
I’m not sure what you mean by your last statement Vinnycolt
07-24-2018, 05:15 PM
Vinnycolt I do not follow what you meant by that last
07-24-2018, 06:19 PM
Our previous TT (Jayco 19H) had the same issue with the outside speakers. The dealer said this was intentional so that you weren't rocking out the neighbors. I called that BS but made no progress in getting the outside speakers to be louder. In our current TT, the volume of the inside and outside speakers seems to be the same - and the quality of the factory speakers is cr@p!
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
07-25-2018, 10:57 AM
Kasual Kamper
After reading this thread, I was curious about outdoor speakers, so I wrote to Crutchfield, who specializes in audio products. They suggested the following (what they call "marine") speaker list:
https://www.crutchfield.com/g_228350....html?tp=61755
To match properly, they would need to know the impedance of the current speakers, and offered the following guide:
https://www.wikihow.com/Measure-Speaker-Impedance
Knowing this, along with the speaker cutout size, they claim they can dramatically improve the performance. I'm tempted...
07-25-2018, 11:13 AM
I am tempted as well.
07-25-2018, 11:54 AM
The Crutchfield sales and customer support people have never steered me wrong.
07-25-2018, 08:48 PM
Kasual Kamper
I asked Crutchfield about this. This was their response: That could be due to the impedance, more that likely they will be 4 ohm. I am thinking it may have to do with the power required by the speaker or the efficiency rating is low on them, those factors could come into play with the volume level.
The radio would not let me know the impedance of the speaker unfortunately, but I show it should have enough power to run some outside speakers without having the inside cranked up. I am thinking it may have something to do with particular speakers they used, more than likely it is there power rating or there efficiency rating, or a combination of both. It turns out that Crutchfield actually sells the Genesis Technologies unit that I have in my 21DS. That's how he was able to know about it. So now I have to dismount one of the outdoor speakers to find out just what I have and the sizing.
07-25-2018, 09:45 PM
As I was contemplating my outside speakers this week, I was thinking they needed to be tilted down some. I have the factory 6.5 unlit on my salem 27dbk powered by a furrion 3050. They dont sound too bad, but I wish they were firing down say 30 deg, more were I am then straight outwards.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
07-25-2018, 10:00 PM
I replaced my factory speakers with these https://www.crutchfield.com/S-soY15S...io-DB-652.html
They are the largest speakers that will fit without cutting. The improvement in sound quality is worth the effort.
2015 Cherokee 274DBH
2015 Ram 3500
07-30-2018, 02:28 PM
I have a set of Alpine components on my 4092BFL. Onkyo RZ820 receiver powers them from the inside.
Since the original cutouts have almost no depth I installed "pods" to give a clean look and more depth.
https://www.crutchfield.com/p_068RPO....html?tp=61890
https://www.crutchfield.com/p_500SS6...5C.html?tp=106
As with most components, they're a little light on bass so I run a MartinLogan Dynamo 700 which is wireless and can easily be placed outside the camper.
