Old 05-03-2014, 09:46 PM   #11
Fulltime family RVer
Originally Posted by bikendan View Post
I assume that's some kind of angry face - don't automatically assume speakers = inconsiderate behavior.
Lots of us have tunes outside and you wouldn't know it. Or if you do- I have come over and talked to you first. I've been asked to "turn it up" without sarcasm before.
ependydad is online now   Reply With Quote
Old 05-03-2014, 09:50 PM   #12
I have regular FR speakers outside, but am considering replacing these with high end marine ones
Kuba is offline   Reply With Quote
Old 05-03-2014, 10:00 PM   #13
I like the cargo door idea. Or I could just bring a radio lol. Thanks for the replies guys
85lolo is offline   Reply With Quote
Old 05-03-2014, 10:18 PM   #14
wfmdfm's Avatar
Relaced the factory ones with these. The sound is great. Notice they are aimed down. seems to keep the sound in my area.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 05-11-2014, 06:09 PM   #15
Jimmerinwi's Avatar
Do you remove the while traveling? What did you do with the holes from the stock outside speakers?
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 05-11-2014, 06:52 PM   #16
wfmdfm's Avatar
No we don't remove the speakers. They only extend 1 1/2 inches out beyond the awning. For the 3 seasons they have been there there has been no issues and I don't see where there will be. The holes where the old outside speakers were I covered. If you look at the picture you will see a white plastic board. I when to Bed and Bath and picked up a cutting board. Cut it in half, sanded the edges and bolted it on the side. I used plenty of caulk and stainless bolts. The bolts extend inside and end up in a set of cabinets where there are nylon nuts and big flat washers. If you need more detail let me know and I can send some more pictures.
Wally
2015 Toyota Tundra
Old 05-11-2014, 07:23 PM   #17
Lynkage's Avatar
Just get your favorite sounding speaker that is a poly cone and all will be golden!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-11-2014, 08:58 PM   #18
camaraderie's Avatar
Not quite...you need a poly or other synthetic cone + a butyl rubber surround + a plastic grill.
Polk db651's would be a good example of a good sounding auto speaker that can also be used outside or in marine situations.
Polk Audio db651 6-1/2" 2-way car speakers ó for 6-1/2" and 6-3/4" openings at Crutchfield.com
camaraderie is offline   Reply With Quote
Old 05-11-2014, 09:17 PM   #19
I dont think you would EVER get the sound quality from bluetooth as from regular speakers. Thats why i asked if youbtravel with it or not. I would just run wires and terminals and hookup as needed. I would look for wired outdoor speakers.
Most people would never be able to tell that an audio stream is Bluetooth A2DP, unless the device started losing connection. A2DP typically provides audio anywhere from 200kbps to 328kbps, depending on quality, which is dependent upon the version of bluetooth being used by both devices, as well as bluetooth signal. Your typical mp3 file is encoded at 192kbps, and higher quality versions are 320kbps.
Don't knock bluetooth audio until you've tried it.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-11-2014, 09:28 PM   #20
Interesting wasn't aware of that, but you would still need a power source for these bluetooth speakers
