Forest River Forums
Sunline User Photos
Old 07-30-2011, 12:35 PM   #21
chromeOkie's Avatar
Originally Posted by sfrye5853
Here's another thought...
"I wanted an easy way to drain the water heater without messing with the plug. So I replaced the plug with a metal braded hose and a ball valve. A lot of people warn not to mix metals with the water heater tank, so I used a nylon nipple between the tank and hose. I also cut the rubber coating from the valve handle so it doesn't end up being melted by the burner. Cracking the pressure valve helps drain the tank." (Jeff's RV Page)
Image of mod...
http://www.jeff-z.com/rv/mods/waterheater-01.jpg
I like this one but would like to hear everyone else's opinion on the mixing of metals. What is the concern about? (newbie here)
2011 F150 Ecoboost FX2 Screw 6.5 bed
2012 FR Tracer 230FBS
chromeOkie is offline   Reply With Quote
Old 07-30-2011, 01:11 PM   #22
Lou Amadio
herk7769's Avatar
Galvanic or two-metal corrosion
Galvanic Corrosion is the issue he is trying to avoid. Two different metals in contact will react with each other over time causing corrosion. Depending on the two metals this corrosion can occur VERY fast and destroy the items in question by accelerated "rusting."
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 07-30-2011, 01:13 PM   #23
sfrye5853's Avatar
Look at your water hook up for your washer at home. Likely you will notice a green-like corrosion around it... Same type of thing.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 07-30-2011, 01:30 PM   #24
chromeOkie's Avatar
thanks Herk, always good info
» Online Users: 528
81 members and 447 guests
02 rockwood, 4bnabird, 4Jeeperz, 8261ss, backpacker3, Barnman1, Bearcat55, bfisher82, bob7794, bouldercamper, buzzmonster, campfun, CampinQueen, carsonizik3, ClampNfish, cstover, djorgensen3, dlmurray51, DonCath25ds, DonG, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, Freds342, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, Kentdb1, kgmat, KKapa, lindy, Mad4sax, mamentt, Marc73, Mike G, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, NO3putt, Pa-cj5, patov6, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, RichN, RickV, Riva, Roamin Ovum, rschroe, Rsgtivr6, Rugged Brown, Russ, ryoucrazey, seatosea, ses, shiggs, Sparkbark, SpringerPop, Stevea1956, tfennell81, tgarner2000, tonybab, transamz9, troyt, UPGRADER, vp22er, Walke, Whiskeyjack, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
