Added an outside shower. Don't forget the six P's.
Before the cut, I prodded and probed to ensure no "Uh Oh's".
After the cut the edges of the wall were reinforced with 1-1/2"
wood stock to create a strong backing for mounting screws.
Sealing Tape around the mating surfaces and Tub/Tile sealer
on the upper and sides of the trim.
I used the brass Sharkbite push on (PEX) fittings.
Photo's:
http://s1185.photobucket.com/user/KA...20Modification
After the shock of cutting into the aluminum skin wore off
I decided to get the Spray Away washdown kit.
Pretty much following the same installation procedure as for the
shower.
Photo's:
http://s1185.photobucket.com/user/KA...Away%20Install
