Old 06-05-2014, 06:59 AM   #1
Spring Mods Outside shower and Spray-Away
Added an outside shower. Don't forget the six P's.
Before the cut, I prodded and probed to ensure no "Uh Oh's".
After the cut the edges of the wall were reinforced with 1-1/2"
wood stock to create a strong backing for mounting screws.
Sealing Tape around the mating surfaces and Tub/Tile sealer
on the upper and sides of the trim.
I used the brass Sharkbite push on (PEX) fittings.
Photo's:
http://s1185.photobucket.com/user/KA...20Modification
After the shock of cutting into the aluminum skin wore off
I decided to get the Spray Away washdown kit.
Pretty much following the same installation procedure as for the
shower.
Photo's:
http://s1185.photobucket.com/user/KA...Away%20Install
KA1VCQ is offline   Reply With Quote
Old 06-05-2014, 07:04 AM   #2
fonzie's Avatar
Outside Shower Modification Slideshow by KA1VCQ | Photobucket
Here are photos???
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-05-2014, 07:06 AM   #3
Yes, photo's.
Old 06-05-2014, 07:12 AM   #4
fonzie's Avatar
Originally Posted by KA1VCQ View Post
Yes, photo's.
I was not able to open your links above, so I had to copy and paste ULR to open photo bucket.....working now. Nice mod and good work.
Fonzie
Old 06-05-2014, 07:15 AM   #5
Thanks and Not sure why the link was not working except that it was a cut and paste
from the Photobucket website.
Thanks again,
Ed
Old 06-08-2014, 02:28 PM   #6
KA1VCQ: where did you get that wash-away? Do you have a website or model #?
Kuba is offline   Reply With Quote
Old 06-08-2014, 02:30 PM   #7
Thanks again,
Ed
73s
Who is the manufacturer?
Old 06-08-2014, 02:37 PM   #8
BamaBob's Avatar
Yes, photo's.
Fonzie...odd, worked for me - click and opened a new window for the slideshow.
KA1VCQ - great job!! When O saw your "finished" photo I thought...big deal, it's a factory installed shower....then I saw the construction photos
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-08-2014, 02:57 PM   #9
Showers are easy to put in. But it takes a while to make the first cut in your new trailer. Or two beers Great job regardles. I did mine two weeks after owning my trailer.
Sent from my Lenovo P780 using Tapatalk
Old 06-08-2014, 02:59 PM   #10
Now..... Where did you say you got that washdown?
Old 06-08-2014, 04:53 PM   #11
Shower and Spray Away
Well I got the Spray Away from local dealer and with gift card. They are not cheap but you can opt for just the connection and store the hose in your "basement." But there are several on ebay now:
Phoenix Prod SA 15 BTW Sprayaway Selfstoring Sprayer w 15 039 Quick Connect Hose | eBay
Pheonix Products Website:
Recreational Vehicle
Look in the "outside" category.
Shower was online store from:
classacustoms on eBay
28 bux.
Plumbing parts from Home Depot but you may get the plastic fittings cheaper at a real plumbing supplier or at your RV dealer.
Old 06-08-2014, 05:08 PM   #12
Thank You,
73!
Old 09-22-2019, 08:59 AM   #13
ELM
Can you use the spray away connection for an air connection to winterize the RV?
ELM is offline   Reply With Quote
Old 09-22-2019, 09:33 AM   #14
Spray Away for Winterizing
I never tried it, but surely seems possible.
Things to check tho:
Interconnections, will air pass in the direction you need.
Water Pump: check valves will not allow air to pass back towards tank, nor shoreside connection.
Pressure: make sure you do not over pressurize the system.
I made up a "special" connection to connect to shoreside water, then blow out all the branches individually. Do this several times over two weeks just to make sure. Then disconnect water pump from both sides (and expansion tank if you use one.) Drain water heater first.
Old 09-22-2019, 11:15 AM   #15
ELM
Winterizing using the Spray away
Thanks for the prompt response.
Good thought about the one way valves. After further thought the air connection to the city water inlet, cutting down the pressure to 40lbs and proceeding to the water tank, faucets including the spray away and finally the water pump seems the tried and true way to accomplish this task.
I appreciate your help
Ed
show, shower, modifications
