Old 06-06-2014, 06:42 PM   #1
BeedoGoesCamping's Avatar
Stabilizer help
So, after reading mods that have added stabilizers, I bought some BAL Lock Arm stabilizing bars. Here's where my problem comes in. My Avenger 32BHS TT is a 4 seasons where underneath is encapsulated with thin cardboard-like material.
Is it ok to cut this stuff to install the stabilizers or should I deal with the rocking and sell my bars? If I can cut into the material, should I try to reseal somehow?
The Covingtons
"Freshman campers!"
2014 Avenger 32BHS
2013 Ford F-150 Eco-Boost Super-crew cab
Number of days camped in 2014: 10
BeedoGoesCamping is offline   Reply With Quote
Old 06-06-2014, 06:54 PM   #2
BamaBob's Avatar
I was wondering the same thing with ours.....
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-06-2014, 07:12 PM   #3
Feel around where the frame mounts go and then cut an I slit and fold it back an have a look. You can always get the alum tape for ducts (NOT DUCT TAPE) and re-seal it. If your worried after you mount the stabilizers, you can always caulk around it. It is just for aerodynamics anyway and protection for the undercarriage components, etc.
Old 06-06-2014, 07:16 PM   #4
Thanks OldCoot. We were told that the material is a sign of a 4 season TT and is there to help with insulation.
The Covingtons
"Freshman campers!"
2014 Avenger 32BHS
Old 06-06-2014, 07:36 PM   #5
Fulltime family RVer
Stabilizer help
I'd be surprised if your camper is a 4-season camper. Most FR campers are moderate 3 to 3 1/2-season campers (at most).
Old 06-06-2014, 07:54 PM   #6
Ddubya's Avatar
I had a similar issue and cut the plastic out to mount the stabilizer directly to the frame. Then used black RTV (silicone) around the area where the plastic meets the stabilizer mount.
Ddubya is offline   Reply With Quote
Old 06-08-2014, 10:55 AM   #7
Some of the trailers have wood strips between the frame and the camoplast. On my Windjammer I had to use extra long bolts from Steadyfast to go through the wood. I mounted the brackets with the wood and camoplast in place. I did have to cut a 3 sided access flap to ensure I was centered on the frame for all 4 bolts. I taped it shut with Gorilla tape. That stuff is crazy sticky.
Linc
missing_link is offline   Reply With Quote
Old 08-19-2014, 12:08 PM   #8
Any pictures of stabilizers installed on a TT? Much appreciated if you have some.
Thanks,
Brian
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
