Old 06-03-2015, 04:33 PM   #11
Originally Posted by richp View Post
Hi,
I have been thinking about adding scissor jacks in the middle on my Silverback 33RL. But I look at the frame and start wondering, "Do I really want to drill holes in that awful thin-looking metal, and what will it do for my warranty?" So I'm drifting in the direction of the cast aluminum screw jacks instead.
Anyone else have misgivings about drilling the frame there?
Rich Phillips
There are brackets that clamp around the frame so you dont have to drill/tap into it. Do a search there are pics and instructions for DIY.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-03-2015, 05:36 PM   #12
Hi Offroad,
Got it -- thanks.
I'll have to look at my rig and see if I have a cross-member like that that I can tie into. I had been looking at the main frame members themselves.
Rich Phillips
richp is online now   Reply With Quote
Old 06-03-2015, 07:07 PM   #13
Timex's Avatar
Hi Offroad,
Got it -- thanks.
Rich Phillips
Rich, look at what I did. Had a welding buddy weld a piece of tubing that slides into the 2" tube over the axle, then welded the jack onto that smaller tube. Then he drilled a hole thru each tube and secured with a bolt. So if I wanted to take the scissor jack off(for some reason), just take the bolt out and slide it out.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-03-2015, 07:13 PM   #14
Hi Timex,
Another great option, depending on what the underside of my Silverback has for a setup.
Rich Phillips
stabilizers, wheel
