Old 06-02-2015, 09:39 PM   #1
Bianchina3's Avatar
Stabilizers near wheels or bracing?
I am trying to decide if I want to stabilize the TT with either jacks (near the wheels in the middle of the trailers) or use braces like JT's Strong Arm (or DIY). Looking for opinions.
My thoughts are:
  1. Overall which better jacks or braces?
  2. JT's are really expensive but look easy to operate.
  3. DIY stabilizers are easier but I am not sure about effectiveness.
  4. Ho do I size the scissor jacks if I go that route.
Any other hints or advice would be great.
Ed,Jennifer, Dixie and Beau Bianchina
2014 Dodge Ram 1500 Crew Cab
2011 Puma 2011 26 RLSS
Days camping in 2017: 25
Bianchina3 is offline   Reply With Quote
Old 06-02-2015, 10:01 PM   #2
Alberta8311ss's Avatar
We installed jacks behind the rear axle. It helped take the bounce out but there is still movement I think the strongarms would fix. I believe we used 24" BAL jacks. When the kids move in their beds you can still feel it up front, but less with the new centre jacks down.
2014 Rockwood 8311SS
Alberta8311ss is offline   Reply With Quote
Old 06-02-2015, 10:03 PM   #3
Name:	ImageUploadedByForest River Forums1433300621.407332.jpg
Old 06-03-2015, 12:18 PM   #4
Bianchina3's Avatar
That is what I was thinking of!
Old 06-03-2015, 12:59 PM   #5
Boss Ox & Drovergirl
oxcamper's Avatar
I have 2 screw jacks, pretty hefty (got them from a farm auction about 20 yrs ag) that were used for railroad cars, and tractors. I put one just forward of the entry door under the frame member and one on the opposite side under the front part of the slide. That with X-chocks has virtually eliminated all bounce and wobble.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-03-2015, 01:31 PM   #6
Who Dares, Wins
doc73's Avatar
Added a second set of BAL jacks just behind the axle and it helped take out even more of the movement.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-03-2015, 02:58 PM   #7
I use jacks, the camco pyramid twist looking ones, in front of and behind the wheels. I snug them up real tight and it takes all the bounce and shimmy out of the TT.
I only use these because I already had them from a previous TT. If I had to buy a fix I would do the DIY Strongarms or scissor jacks mounted.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-03-2015, 03:24 PM   #8
offroad's Avatar
Here is a post about the Husky scissor jacks I mounted in front of the axle on our TT. It took a lot of the movement out, and those jacks are much better made than what FR shipped on the trailer.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 06-03-2015, 04:20 PM   #9
Hi,
I have been thinking about adding scissor jacks in the middle on my Silverback 33RL. But I look at the frame and start wondering, "Do I really want to drill holes in that awful thin-looking metal, and what will it do for my warranty?" So I'm drifting in the direction of the cast aluminum screw jacks instead.
Anyone else have misgivings about drilling the frame there?
Rich Phillips
richp is online now   Reply With Quote
Old 06-03-2015, 04:28 PM   #10
offroad's Avatar
Check out the link I provided earlier, I didn't drill any holes in the frame to mount my jacks.
I reversed the jacks mounting ears then welded them over the top of one another, and added a length of 1 1/4" x 1/8" metal strap to the top of the jacks on a slight angle.
The the straps were bent in a U shape, then I could just bolt the jacks over the top of the tube running in front of the axles. Easily removable with only one bolt.
If you click on the picture in my link you can get it big enough to explain.
I cut the long portion off a cheap jack wrench, ground flats on it and use that in a cordless drill to lower them.
stabilizers, wheel
