Old 06-08-2013, 03:39 PM   #21
onetonford's Avatar
Originally Posted by herk7769 View Post
I looked at doing it and it is still on my mod list; but I am having trouble finding a Saturn jack. The jack has to be short and most that I have found so far are too tall.
I like the strengthener as I have been looking at the flex when a person is on the steps and it is the floor that moves the most.
Here is what I just got done yesterday on my steps Herk
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-08-2013, 04:08 PM   #22
Blaster 84's Avatar
They look good and they look like they are adjustable. Once adjusted how do you lock it in place?
2020 F250, 7.3 gas, 34 ft. Fifth Wheel, SOB
Blaster 84 is offline   Reply With Quote
Old 06-08-2013, 04:13 PM   #23
onetonford's Avatar
The picture is not from the front due to being next to wall but looking from the front of steps they are angled out ward so they tend to self lock in place.
2011 25 RL Wildcat
Old 06-08-2013, 04:25 PM   #24
Looks good, Great idea. I have some short pcs of alum tubing from somewhere or other that would be ideal. Will just get some 5/8" threaded rod and make them screw adjustable. Thank you very much onetoneford.
Old 06-08-2013, 04:43 PM   #25
onetonford's Avatar
Mine are adjustable have internal threads that the inner tube is adjusted on. The outer Tube is 3/4 " EMT and the Inner tube is S/S tubing with a nut welded on the top side threads are welded to a piece of tubing that fits inside top 1 inch of 3/4 tubing and then are crossed drilled for the top swivel bolt. all this is mounted into 1-1/4 " square tubing which I cut out to clear legs and to give side support. then on the bottom are two home made swivel bases to fit some foot pads I got off a cargo lock bar.
They are adjustable from 7-7/8" to about 13-1/2"....
2011 25 RL Wildcat
Old 06-09-2013, 08:58 PM   #26
10x
Would a scissor jack work under the step?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 06-12-2013, 10:35 PM   #27
onetonford's Avatar
I guess it would but you really just need to keep them from flexing. The only thing I learned is not to over extend the stands because the steps try to fold when you get to the next step so I just adjust so they just touch the ground and it works great. I got the Idea from E-bay on one that someone sells that only has one leg but I like the Idea of two.
2011 25 RL Wildcat
Old 07-11-2013, 07:48 PM   #28
svo
removed
svo is offline   Reply With Quote
Old 07-11-2013, 09:29 PM   #29
gooiebob's Avatar
I just put a harbor freight brand scissor jack on my trailer today. I mounted it between the steps and the front tire. I used it for a week to stabilize the ultra lite frame on the 2703. Chizeled out the wood on the bottom of the frame and mounted a 2 1/2" square tube to the frame. Had to work around the gas line. Works great.
Bob
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 07-12-2013, 08:07 AM   #30
Paul & Sheri
pwb01's Avatar
That's a good idea. To address the same situation, Similar to Onetonford's photos I found at Amazon a step support that is a small adjustable screw jack to put between the ground and the bottom step. They have a 4" to 8" and one a little longer for about $12 to $16. They are two flat plates on each end of a screw adjustable shaft. (search RV Save-a-step brace)
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-12-2013, 08:15 AM   #31
This is what I use. Bolts around the 3/4" tube on the 2nd step and swings in for travel.
ID:	35147   Click image for larger version
Old 07-13-2013, 09:22 PM   #32
ryand's Avatar
Oldcoot- can you show this installed? Having a hard time seeing how it works.
2019 SOB Bunkhouse (Former Coachman FR Owner)
2015 Ram Bighorn 2500 6.4L
https://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 07-13-2013, 09:40 PM   #33
Pictures in post #1 of this thread. http://www.forestriverforums.com/for...sis-42140.html
You will have to ask Herk how it works.
Old 07-15-2013, 04:47 PM   #34
Paul & Sheri
pwb01's Avatar
One works but I think two would work much better. I just ordered the second.
2006 Sunline T1950
2004 T@B T-16
Old 07-15-2013, 05:04 PM   #35
trudinator's Avatar
Very similar to the ones we just ordered from Camping World. They make a WORLD of difference. No flex, no camper rocking, etc. I highly recommend everyone do this mod. If you watch someone go in and out of your TT, you'll see the just how much they flex. I can't see the steps/frame lasting the lifetime of the TT without proper support.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
