01-20-2015, 12:00 PM
stinky slinky mod
I know I have read about using a fence post and hotter to make this mod but would like a little more info concerning the length, the width how to attach caps and of course the same on the gutter. I intend to use u-bolts to attach to bumper. Help if you can and remember that I am a woman if that makes a difference. Lol
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
01-20-2015, 12:12 PM
Always Learning
I used pop rivets. I had to buy the tool ($25 or so) and basically used it to attach everything together.
You have to drill a hole first for the rivet fit through and then you just squeeze the tool to pop-one in.
A couple of places where I thought things might catch, I just filled the backside of the rivet down. As you assemble it, it'll be clear.
As for lengths, I went for the full 8' so that I didn't have to cut the fence post. I did have to cut the gutter and used a fine tooth hand saw for that. I just cut the gutter an inch or two shorter.
The fence post is the 5" size and the gutter is the same. The fence post end caps are in the same area as the fence post. Make sure you get gutter that is symmetrical when you look at it from the end. It makes a slightly better tray that way. In the same aisle near the gutter will be the end caps.
My latch came out of the hardware area. And I use small hitch pins to hold it shut.
Always Learning
Wish I had pictures but the camper is in for work and I've switched phones since then.
01-20-2015, 07:58 PM
Thanks! You gave me more help than you know. Now for a little extra cash and a warm weekend.
Sandy and Steve
Vinemont, AL
01-20-2015, 08:20 PM
We did the same thing with the pop rivets, bought one at Harbor Freight for around 10 bucks, worked great.
Make sure you get the 5x5 post (vs 4x4) as I don't think you can do the gutter slide in the smaller posts. We also bought gutter end caps and pop riveted them in to the gutter, and then screwed a handle on one end. Only cut the gutter down, used a fine tooth saw like ependydad suggested. Make sure it's at least a few inches shorter if you want to put a handle on it.
We also used pop rivets to put on hinges and a latch on one end cap. Total, I think it took us a couple of hours to build, and we also drilled holes in the fence post and the gutter for drainage and airflow.
My husband and I have a class A, so no bumper for us, once we get out in the spring we'll use some giant zip ties to put it underneath the chassis somewhere.
We only needed a pop river gun, a drill, a hacksaw and a screwdriver to complete, it's a pretty straightforward thing to do. The pop rivets are FUN. I had never used them until now, and they were really easy to use.
Good luck!
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
01-21-2015, 11:27 AM
I use fence post storage myself, but not for the slinky (I paint the inside of my bumper carriers with POR-15 after drilling drain holes in the bottom - has worked on past 4 campers fine). I use them to store awning braces (I have an electric awning that I made wind props for), fire tools (cooking forks, pie irons, log tongs), and my awning mat. You're going to cut the fence post somewhere around an 8-foot length give or take a few inches either way depending if you wanted more tucked out of sight or more easily accessed. Another thing you can do with end caps is to attach them with a pair of draw latches:
McMaster-Carr
I use stainless steel ones attached with low-expansion aluminum rivets (you can cause the PVC to crack if you use the wrong rivet). Two latches per cap, mounted on opposing sides. The reason I do this is because I like to take the entire cap off and out of the way, but more importantly because I have installed weatherstripping on the inside of the caps so that my tubes, except for the awning mat one, are sealed from the elements and insects.
Also, note that you might need to shim your tube off the frame rails a little bit to clear things like gas lines or the J-wrap (bottom trim panels on some campers) so you're U-bolts might need to be longer than you think.
01-21-2015, 11:36 AM
Does the 5x5 fence post accept the slinky and the 90 elbow as well?
Craig & Lynn D'Angelo
Delaware
01-21-2015, 11:38 AM
Always Learning
My elbow, wye, sewer donut, and some caps live in a tote in the storage hatch. My plan is to mount a battery box on the bumper to move them there.
01-21-2015, 11:40 AM
My cheap rigid 90 would fit but not the swivel rhino 90. I bought a swivel 135 (mislabeled as a swivel 45) instead that fits in the post.
01-21-2015, 12:03 PM
Been there, done than, have the Mod Sandy (I think I demo'ed it as last year's BamaGanza
Here is the thread I started on the subject (complete with pictures!)
http://www.forestriverforums.com/for...ods-57842.html
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
01-24-2015, 06:32 PM
Ok I go out to measure bumper in order to know what I need to attach stinky slinky mod to bumper and fine a sticker that says "addition of any non-factory installed components to bumper assembly is prohibited and may void chassis warranty". Now where does that leave me?
Sandy and Steve
Vinemont, AL
01-24-2015, 06:49 PM
Mount it to the trailer frame just behind the tires, you will not be adding anything to the bumper that way.
