Forest River Forums
Sunline User Photos
Old 01-07-2012, 11:59 PM   #1
dilgerc's Avatar
Storage box
I would like to build a frame to mount a 5' aluminum box to that I could mount on my rear bumper using two of the universal recievers that bolt to the four inch square bumper. Putting one reciever on each side by the main frame on my 2012 vlite. I would like any advice on my idea. Thanks
dilgerc is offline   Reply With Quote
Old 01-08-2012, 12:12 AM   #2
Hob
Old Fart
I don't know that I would do that. From what has been discussed on here, any frame addition or modification seems to void your warranty from what people have been saying.
Hob is offline   Reply With Quote
Old 01-08-2012, 04:19 AM   #3
Mountainmanbob's Avatar
I agree with Hob
after reading about MANY frame problems
one must be careful
if you know about welding and the such
before attaching anyTHING to the frame
inspect the frame for cracks
missing or weak spot welding beads
should be not a problem to add to main f
but
some extra beefing up may be necessary
you can kiss your frame warranty good bye
these guys seem to be looking for
any excuse
to bail out on you
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-08-2012, 05:38 AM   #4
We have a 30wfk V,it was a death trap to tow with the rear fw tank & w/h. F/R has since moved these foward.I removed everything from the rear bumper to help this problem. I only have a sewer hose in the bumper & a NPS decal on the bumper. My vote is (NO) on bumper use! Youroo!!
Old 01-08-2012, 05:45 AM   #5
I agree with the others due to the frame problems folks have been posting about on here.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-08-2012, 06:20 AM   #6
with my welding and frame experience
as an Equip Tec
I would call this
a shame as we think about it
most all frames should be able
to handle some extra weight added
to the rear end
when properly installed (bolted or welded)
frames are usually
not
made so very weak
that not only should one not add to
but
must worry about the way in which
it came factory direct
while working at the City as Equip Operator
we at one time
ordered what looked to be
super light weight trailers
so as to haul some of the smaller
riding mowers
we all had second thoughts regarding these
but
even these weak looking trailers
although used for many many years
by some abusive Operators at times
I never remember breaking
now after reading many posts
I'am even concerned
when using the leveling jacks
do these little THINGS
put stress if not
raised gently and evenly ???
I'am being very careful with my frame
after a lifetime of repairing THINGS
now retired
I just want to go camping
not adding to
and
keeping an eye on this THING
seems to be possible
preventive medicine ???
Mountainman
Old 01-08-2012, 06:51 AM   #7
Lou Amadio
herk7769's Avatar
Having seen the cosmetic tack welds that hold that (mostly) decorative bumper onto a minimally sized frame for the stated gross weight; I also say "Bad Idea."
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 01-08-2012, 07:45 AM   #8
The aluminum box would probably be ok, but you wouldn't be able to put anything in it. The frames on these campers are simply too light to support much additional weight. You would end up bending the frame, guaranteed. That is unless the box simply ripped right off and killed some innocent driver.
Old 01-08-2012, 08:41 AM   #9
Fire Instructor's Avatar
I was worried about the above stated frame stress, and adding weight behind the axles, making the TT tail-heavy, so I added a much smaller (30") plastic/composite box there - I slid the spare tire mount from the center to immediately next to the ladder, and then the shorter box fit fine. All I store in this box is my macerator pump and hose, an extra length of sewer hose, and various drin fittings, donut, rubber gloves, etc... everything related to waste water disposal. This keeps it away from everything else. The box, and everything in it, total less than 50 lbs., but it frees-up space elsewhere.
I then removed the factory battery box, moved the propane tanks slightly closer to the electric hitch jack, and a 5' long, 12" wide aluminum pick-up truck storage box (from Lowes) fit in there fine. I vented the back of it before installing, and this became the battery box for my pair of 6v golfcart batteries, plus it holds leveling links, wooden blocks, folding flagpole stand, and army-surplus folding shovel and trenching tools.
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 01-08-2012, 10:38 AM   #10
dilgerc's Avatar
Ok y'all confirmed my gut feeling on this so it's a no go on the storage box on the bumper. Just wished I had more storage. Thanks so much for all your advice and good job on yours fire instructor.
» Online Users: 525
82 members and 443 guests
02 rockwood, 4bnabird, 4Jeeperz, 8261ss, backpacker3, Barnman1, Bearcat55, bfisher82, bob7794, bouldercamper, buzzmonster, campfun, CampinQueen, carsonizik3, ClampNfish, cstover, djorgensen3, dlmurray51, DonCath25ds, DonG, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, Freds342, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, Kentdb1, kgmat, KKapa, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, Mkayers, Mpwelch50, mtnguy, NeilM108, NO3putt, Pa-cj5, patov6, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, RichN, RickV, Riva, Roamin Ovum, rschroe, Rsgtivr6, Rugged Brown, Russ, ryoucrazey, seatosea, ses, shiggs, Sparkbark, SpringerPop, Stevea1956, tfennell81, tgarner2000, tonybab, transamz9, troyt, UPGRADER, vp22er, Walke, Whiskeyjack, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
