Old 09-12-2013, 07:32 PM   #121
I used two SS nuts/bolts/fender washers on either side of the frame's I-beam flange. I cut two washers in half to make up for the thickness of the flange. So a total of 2 sets of 2 on each side of the TT. See attached drwg of the bolts on one I-beam. I did NOT want to drill ANY holes in the frame.
2011 Traverse LT, 3.6L, FWD
Old 09-12-2013, 07:39 PM   #122
Note that I have a slight error in the side view on the right side. The top washer/nut should be just above the two cut-in-half washers, similar to what's shown on the view at the bottom of the picture.
Old 09-13-2013, 07:45 AM   #123
Take The Road Less Travld
MuddauberE's Avatar
I can see how that works. Good Ingenuity! I just drilled the holes
.....Are you drilling through the 5" post? Looks like that's what you're doing in your drawing in the side view. Guess that's one way of doing it.
MuddauberE is offline   Reply With Quote
Old 09-15-2013, 07:35 PM   #124
Yes. Insert the SS bolt and fender washer from inside the post, add the two half washers, then put the top fender washer on top of the I-beam flange, then the nut. Used nylon lock SS nuts. Total of 8 sets, 4 on each side of trailer, two on each side of each I-beam.
Old 09-23-2013, 09:15 PM   #125
Originally Posted by Kaadk View Post
Anyone find the 5x5 posts on the northern side of the border? All I can find up here at HD/Lowe/Rona/Local stores are sized 4x4.
I agree. These posts are hard to find in late summer. Hardware buyers must think Canadians only build snow fences after August 1. After numerous phone calls I found an observant employee who knew about a pallet of 5X5 vinyl posts at a local HD this weekend (mid September). They'd been sitting there for weeks. It took them almost an hour to discover they had no information on cost or anything in their system. The posts had been discontinued. Got a deal. $20 for one post.
2010 Surveyor 23'
Blaupunkt is offline   Reply With Quote
Old 09-27-2013, 10:44 AM   #126
retiredguy's Avatar
hi all, just wanted to offer another solution if you can't find post guards. (I couldn't in Calgary). Since we are in irrigation country, I picked up a piece of 5" aluminum irrigation pipe. Light and strong. Will be mounting it above the back bumper.
2013 Windjammer 3025
2018 Heartland trail Runner sle 265
2012 GMC 3500 6.6
2011 Razor 800
http://dougbevswanderings.blogspot.ca/
retiredguy is offline   Reply With Quote
Old 11-10-2013, 07:15 PM   #127
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
Forgot to post and to say thank you for all recommendations. Last week I completed my installation of sewer hose storage, plus I added another to hold fishing rods.
They look great and work awesome.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 11-11-2013, 09:48 PM   #128
golfmedik's Avatar
Very nice!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 10-30-2014, 05:54 PM   #129
beeman's Avatar
Following
2002 Chevy 1500HD
2015 Flagstaff 832IKBS Diamond
beeman is offline   Reply With Quote
Old 11-06-2014, 12:36 PM   #130
Retired
RubyDually's Avatar
I want to do this mod on my new Sabre but have reservations about drilling holes in the frame of the trailer.
Has anyone had any issues drilling the frame?
What about FR or Lippert if you have frame issues later on down the road? They may blame your mod as the cause???
Just wondering guys.. I luv the mod!
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
