Old 11-06-2014, 12:59 PM   #131
Herk7769's Avatar
I waited till I was out of warranty.
I doubt there will be any repercussions, but you never can tell.
A crack originating in a hole you drilled would be tough to claim as a manufacturing defect.
However, many camper frames get cracked due to overloading and bike racks; so it may not matter; won't be covered anyway.
HAM CALLSIGN - KC3FFW
Old 11-06-2014, 01:38 PM   #132
Phat Phrog Stunt Crew
elind's Avatar
When you install JT Strongarms on your RV the arm mounts are drilled into the frame. These are Lippert products, so if was bad they wouldn't do it?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 11-06-2014, 02:02 PM   #133
Retired
RubyDually's Avatar
Excellent point!
How did you know I was planning on installing those too!
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 11-06-2014, 02:30 PM   #134
Kaadk's Avatar
First take a look for any existing holes. I found them on mine and reused instead of drilling new. Some others on here have found ways to clamp them without drilling new holes as well.
If you do end up having to drill holes, make sure you stop and think about the load first. Try to drill in the least load bearing point of the frame.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 11-06-2014, 08:19 PM   #135
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
I had same reservations until I looked underneath, holes were already in frame, so please check it out first.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 11-06-2014, 08:53 PM   #136
B and B's Avatar
Beam clamps used for attaching pipes to structural steel for pipes and conduit.
Name:	Beam Clamp.jpg
I would use one on each side total of 8 to attach one fence post. No Drilling.
Previous poster mentioned JT's, they are attached with self driving number 14 or 16 screws.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 11-06-2014, 09:33 PM   #137
I've posted this before, but if you're using a fence post, I clamped mine to the flange of my frame with stainless steel nylon insert locking nuts, bolts and fender washers. The bolts are right next to the flange. There's a fender washer on top of the flange, two halves of a cut washer to make up the thickness of the flange, and a fender washer inside the post. Attached pic is not totally correct, but you'll get the idea.
8 sets of nuts/bolts/washers total: 4 on each frame rail, 2 on each side of the frame flange. You need to adjust the number of half-washers based on the thickness of the flange on your frame.
It's been on for 3 seasons. No problems.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-07-2014, 09:53 AM   #138
Retired
RubyDually's Avatar
Thanks for the replies. They gave me ideas so I don't have to take out the drill. I just have to wait until fence posts are in stock at HD in the spring.
Trailer is in storage now but I recall from the PDI the brackets for JT Strong Arms are already there so that should be an easy project.
Thanks again!
Old 11-07-2014, 04:45 PM   #139
You can order them online. It says if you ordered it today, you'd have it Nov 19-21.
Veranda White Vinyl Fence Post (Common: 5 in. x 5 in. x 8 ft; Actual: 5.0 in. x 5.0 in. x 96.0 in.)-73010700 at The Home Depot
Here's the rain gutter to put in it, from Lowes:
http://www.lowes.com/pd_12066-322-RW...ter&facetInfo=
I'll let you find the end cap for the fence post and the end caps for the rain gutter on your own.
