Old 06-18-2013, 08:48 PM   #31
Herk7769's Avatar
Originally Posted by crushor View Post
My question on these storage tubes...if memory serves me correctly they are 5" vinyl fence posts. All the posts that I have found have rectangular slots cut out of them for the fence rails. Are you finding them without the slots, sealing the slots up, or ?? I have looked at both Menards and Lowe's. the guttering is...well, easy to find.
There are 5 inch posts without the slots too.
HAM CALLSIGN - KC3FFW
Old 06-18-2013, 09:02 PM   #32
crushor's Avatar
I assumed there would be. I guess I need to choose better points of contact at the stores, as both provided me with the same answer...they didn't sell them.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 06-18-2013, 09:10 PM   #33
Herk7769's Avatar
Home Depot had the 5 inch Posts and Caps; but not Lowes.
Lowes had the perforated steel bars; Home Depot didn't.
Lowes had the correct 4 inch rain gutter (symmetrical); Home Depot did not.
Home Depot had the 1/8 inch vinyl clad steel cable; Lowes was out of stock.
Home Depot had the 3/16 Clad Copper Ferrules; but not the crimping tool.
Lowes had the crimping tool but not the Ferrules.
<sigh>
Old 06-18-2013, 09:18 PM   #34
crushor's Avatar
Herk, thank you. As usual your wealth of knowledge is amazing. Especially to those of us in our Sophomore year of camping.
Old 06-18-2013, 09:20 PM   #35
golfmedik's Avatar
<sigh>
Here is the post from HD Veranda 5 in. x 5 in. x 8 ft. White Vinyl Fence Post-73010700 at The Home Depot
They should also have a couple of different style caps in stock too. I used 1" aluminum tubing for mine and like Lou said, Lowe's has the gutters that I use for this purpose.
Works really well when the sewer hook up is above the ground, like the beach.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 06-18-2013, 09:26 PM   #36
Herk7769's Avatar
I used the "inside" end caps and pop riveted them in place.
I did not need to use a dowel for a handle.
Old 06-18-2013, 09:34 PM   #37
B47
Like most of you, I have always thought of Loews and HD when buying almost anything for the home or yard etc. There are plenty of both here in the DFW Metroplex.
But a recent experience I had made me turn to a third source for things I would usually go to either Lowes or HD - that being Ace Hardware.
We recently had a outdoor patio extension poured - it's nice with a textured surface and stained to a pecan finish. We want to keep it looking new for as long as possible and we decided to replace the plastic inserts in the bottom of our outdoor furniture feet that were worn out.
I took an old insert with me and went to Lowes with no results. I went to HD and they didn't have any either. I then remembered there was a large Ace Hardware that opened about 4 years ago that isn't too far from our house.
I went in and showed the Ace guy that met me at the door ( how often does that happen at a big box store) what I needed and there they were - I depleted there stock, but they ordered more for me.
This is a big Ace and I was surprised at what they have - I will keep them in mind next time I need something that Lowes or HD doesn't have.
B47 is online now   Reply With Quote
Old 06-19-2013, 03:31 AM   #38
golfmedik's Avatar
Whenever I am looking for any type of fastener, whether it be rivets, bolts or anything stainless, I forget the big store and go directly to Ace. There selection is far better than the other two put together and they usually have enough of the product I need. Plus, like you said, much more helpful than the box store.
Lou, the reason I put the dowel in mine is to aid in the draining of any excess water that gets in the tray. I didn't want it to be held, I want it to drain into the tube itself and then out the bottom.
Old 06-19-2013, 06:00 AM   #39
Toad Haul's Avatar
Found this option for a sewer storage tube. My camper has the emerald package, eg., tan with tinted windows, and I wasn't after a white storage tube. I'm not sure how these mounting brackets align with the frame, but I'm gonna check it out.
Sanitubes / Sewer Hose Carriers / SUPER-TUBE - DW Inc.
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 06-19-2013, 06:06 AM   #40
Herk7769's Avatar
Yea, I can see the benefit of that. Might have to drill some drain holes...
Always a tweak...
Oh, BTW, using the rain gutter I can fit my (collapsed) 25 foot hose and my 2 5 foot extensions with sanitary elbow in the tray. A 1 gallon Ziploc has the clear elbow and the threaded part of the sanitary elbow (stored in basement).
