Old 07-11-2013, 07:20 AM   #31
avolnek's Avatar
I'm with Keller... I mounted a box up on the front tongue for the battery and the hitch... When I am towing the trailer, the blocks of wood used on the ground and wheel chocks replace the hitch...
Name:	Daisy front storage.jpg
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-11-2013, 08:01 AM   #32
keller9431's Avatar
I also went as far as to put a battery disconnect on the trailer. This way my battery doesnt go dead when it is sitting there not being used. I mounted it down on the frame and used Liquid tape to waterproof the connections. Works great!
keller9431 is offline   Reply With Quote
Old 07-11-2013, 12:42 PM   #33
I added a very similar box to trailer last week after someone stole my battery. It was around $60 at Wal-Mart. I'm not 100% happy with how I mounted it, but I'm not unhappy enough to redo it.
Grim is offline   Reply With Quote
Old 07-11-2013, 12:53 PM   #34
avolnek's Avatar
X2... If the harbor freight box was a little thicker walled that is what I would prefer...
I also installed a 7 pin female plug like what would be on the back of the truck with a fuse link between the +12v pin and running lights pin. This way I can plug in the loose end of the cord to keep it off the ground. Then at night the running lights are on and gives off a unique look... I pull the fuse out during the day to keep the lights off...
Old 07-11-2013, 12:58 PM   #35
keller9431's Avatar
I like those boxes you guys. Granted the HF box is not very thick metal, but once I had it mounted down it seems to be ok.
Old 07-11-2013, 01:03 PM   #36
avolnek's Avatar
I'd have to say yours looks a lot nicer Keller... just worried me having the lighter weight steel hanging out in front here in the midwest salt will rust just about everything!
once this box fails me I'm custom building one... I work at a sheet metal shop so I will just have em zip one out of diamond plate for me...
Old 07-11-2013, 01:31 PM   #37
X2...I also installed a 7 pin female plug like what would be on the back of the truck with a fuse link between the +12v pin and running lights pin. This way I can plug in the loose end of the cord to keep it off the ground. Then at night the running lights are on and gives off a unique look... I pull the fuse out during the day to keep the lights off...
Just made a cup with an open bottom to store the pigtail in on our tt.
Name:	Holder with open bottom for 7 pin connector.jpg
Old 07-11-2013, 01:38 PM   #38
keller9431's Avatar
I live in Ohio so the salt does eat everything. I will probably paint the box with Rhino Liner or some generic brand to protect it from the salt.
Old 07-11-2013, 01:41 PM   #39
avolnek's Avatar
That would be pretty sweet! Will have to keep that in mind if I create one of my own!
Old 07-11-2013, 01:42 PM   #40
avolnek's Avatar
OC dont you pull a 5er?
