Old 08-28-2013, 02:25 PM   #1
DDC
DDC's Avatar
Storage not using bumper
I wanted to be able to take my generator and gas but not in my TV or in the TT so this is what I have done, I raised it so I would not have to house the battery, access to the battery requires removing four nuts but no big deal although I may add a cut-off switch later.
ID:	38796   Click image for larger version
ID:	38797   Click image for larger version
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-28-2013, 05:15 PM   #2
H2oski
Great job, It looks good.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 08-29-2013, 07:01 AM   #3
you just gave me an ideal. can you post pictures of how you mounted the box and some info on it.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 08-29-2013, 07:40 AM   #4
Brother Les's Avatar
Originally Posted by prothos View Post
you just gave me an ideal. Can you post pictures of how you mounted the box and some info on it.
x2 ........
Brother Les
Old 08-29-2013, 06:44 PM   #5
DDC
DDC's Avatar
I used 1 inch perforated steel tubing from ( home depot or loses or similar place) 3/8 th threaded rod cut to the length needed ( mine was 8 pieces 8 inches long) for the carrier I used 1.5 angle 1/8 thick ( I would have preferred alum. but was expensive here) cut to size , I needed 4 pieces 6 inches long to clear the battery, two pieces the depth of the box and one piece for front and back of box. Bolted together with 5/16 bolts and ny-lock nuts and flat washers, the box I got from costco it's a tradesman 21, I had to alter the lock to suit my set-up. It took longer to plan than it did to put it all together, hope this helps as I did not take pictures as I was putting it together.
storage
