Old 02-11-2013, 04:09 PM   #21
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by Tblackmon9599 View Post
Ragin Cagun. I did a similar mod but have had a hard time with end caps. Looks like you used a threaded bolt through side to side?
Yes, used a hex bolt 1/4" x 6"...have a lock washer and wing nut to keep it on.
With the cap in place, I drilled in the center for the best strength and drilled with 1/4" bit, which will be snug at first but after sliding the bolt in and out a few times, comes out easily.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-12-2013, 08:23 AM   #22
CB, is that a 5" PVC post?
Yes it is.
C.B.
cbvp is offline   Reply With Quote
Old 02-12-2013, 09:58 AM   #23
Fulltime family RVer
Do you mind showing close-up pictures of how you mounted your storage tubes? I'm pretty sure my wife is going to demand that my two don't live in the back of the truck shortly into this year's camping season...
ependydad is online now   Reply With Quote
Old 02-12-2013, 07:55 PM   #24
Camper Less Camping
I'll get a pic of mine tomorrow
Old 02-12-2013, 08:12 PM   #25
Thanks kind Rager.
Old 02-13-2013, 08:44 AM   #26
Camper Less Camping
Thanks kind Rager.
Here we go, very simple install with my camper already having these brackets in place here
Old 02-13-2013, 09:11 AM   #27
Hmmm... wonder if I have a bracket like that.
Old 02-13-2013, 09:43 AM   #28
CapsFloyd,
I also have a Flagstaff and the Rhino sewer hoses. Actually we have 4 10' lengths. The first time I tried to put them into the square rear storage compartment I also didn't think they would fit. I tried it again one more time and they did. You have to rotate until the latches align with the corners of the square tube. They should fit unless of course they have a smaller square tube. Try it again and maybe it will fit. I stuff at least 3 or maybe all 4 of the 10' lengths into the tube.
TeJay
TeJay is offline   Reply With Quote
Old 02-13-2013, 09:44 AM   #29
Capsfloyd's Avatar
On my flagstaff the underside is completely covered
Mine is bumper pull
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 02-13-2013, 04:37 PM   #30
On your post 1o you said that your Rhino hoses didn't fit into the rear storage bumper on you Flagstaff. Now you say that you're underside is completely covered and is a bumper pull. Mine is also and the rear storage bumper does allow the Rhino hoses to fit.
It can be tricky at times to communicate ideas.
TeJay
