01-19-2015, 10:35 AM
AKA: 'tiredTeacher
Storm door mod
Has anyone added plexiglass to his screen doors to turn them into storm doors? Any pics of the project?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
01-19-2015, 10:47 AM
01-21-2015, 06:27 PM
Yes I did and it is great the dogs and the I can look outside and don't lose much heat I love it
Sent from my IPhone
01-22-2015, 06:24 AM
Did mine also....works great. I made separate pieces for the door so I can remove what I want if needed.
01-22-2015, 08:41 AM
I've done it on 3 of mine so far and love it. I first cut a template from cardboard for the 2 pieces, top and bottom. Then I removed the screen completely. On my screen doors there was enough of a lip/cavity on each side so that the glass would almost stay in place without screws, but not good enough to withstand the slamming and movement. So, I predrilled holes and used very small (I think very short #6) stainless sheet metal screws through the glass and into the door frame to secure in place. Also, get a very good jigsaw blade for plastic from Lowes, Bosch makes some really good ones. The hardest part is trying not to scratch the glass while working with it.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
01-24-2015, 01:27 AM
On our 2012 378XL I had a local glass company do our and is was 120 bucks and I had them use the dark plexi glass so you can see in but we can see out. They installed it and then used the rubber around the entire door so it holds it secure and tight. Had the top/bottom and the middle done for that price. I priced the stuff at lowes and figured it would be cheaper going the route I did. Since we full time didn't have all the tools to do it myself. I'll try to post some pictures once the rain here stops (Florida).
Andrew & Donna Reyes 2012 Georgetown 378XL 2015 Ford Taurus & Our Baby Dachshund Cammie
01-26-2015, 08:08 PM
Permanent fifth wheel
Ramir
Look forward to the photos. Best idea I have heard of for the screen door.
01-26-2015, 08:15 PM
Blog: RVroadtripper.com
I used Lexan from Lowes. Get your measures right and you can do it in one sheet. About $65 and Lowes does the cuts for free. Pieces slip into the grooves around the screen. I used a couple of velco strips to make them tighter but honestly I think the Velcro wasn't needed.
01-26-2015, 08:25 PM
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
This is a pic of the plexiglass I added on our 2014 Jayco bunkhouse screen door.......we traded in mid-October for our 2014 Silverback 33RL and it came with a screen door with clear vinyl panels already mounted on the door....the panels on the Silverback are designed to go on and off much easier.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014-38nights/3500 mi; 2015-66nights/6260 mi;2016-44 nights/6106 mi;2017-65nights/6992 mi;2018-47nights/7376mi;2019-65nights/7825 mi;2020-59nights/4142mi;2021-39nights/3072 mi;2022-59-nights/6149 mi;2023-36nights/3001miles.
01-27-2015, 09:27 PM
355re: Here are a couple shots of our screen door.
1st one is inside looking out
2nd outside looking in
3rd The screen door is open and showing the gasket around the plexi-glass
02-07-2015, 07:09 AM
So, is it necessary to remove the screen? Can the plexi be placed over? I have a Sandpiper 376BHOK, and would love to do this to our door!
2015 Sandpiper 376 BHOK
02-07-2015, 08:04 AM
Always Learning
It is not necessary to remove the screen.
02-07-2015, 09:22 AM
X2
02-07-2015, 02:35 PM
Just Love to Camp
Not necessary to remove the screen but makes it easier to keep clean
Camped 54 Night 2012
XLR Thunderbolt 386*12
" Bertha The LeadSled" is her name
2012 F450
Virginia
02-07-2015, 02:40 PM
The glass could be applied using magnetic tape. This would make it easy to remove and clean.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
02-07-2015, 10:04 PM
The lexan can be thin and with some close cutting, fit in the inside groove next to the screen. 3 pieces, top, bottom, and opening next to slide. Easy to do. Measure and use a straight edge. With a razor knife, score one side and simply snap. Sand the edge and pop into position. I used clear mirror mounts with small sheet metal screws. To make the rounded top of the door, I used a large coffee can to score the radius.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
02-09-2015, 03:15 PM
I did this in our last 5th wheel but haven't done it in the TH yet. I would remove the screen for easy cleaning and clear view. I installed ours in the groove and then used silicone to seal it up. That way even with the door open in the rain I didn't have to worry about water. I had used clear plexiglass last time but am gonna go with tinted this time.
