Old 04-24-2012, 07:28 PM   #1
DDC
DDC's Avatar
Stove top hood fan
Has anyone ever tried to put in a rheostat to control the fan speed on the hood fan over the stove?
DDC is offline   Reply With Quote
Old 04-24-2012, 09:54 PM   #2
TURBS's Avatar
I do not know why you couldn't !
im guessing yours like mine just screams !
Old 04-24-2012, 11:23 PM   #3
Mine is a simple DC motor, so lowering the voltage should decrease the speed. Now I have to ask, did you release the little lock down tabs on the flap outside before toy ran the fan? Makes a world of difference. Withe flap locked closed, the fan has no resistance, and will scream. If you open the little tabs, and let the flap open, then the fan will move some air, and is quieter, plus that is the only way it works.
DO lock it back down before towing, or you will be buying a new flap.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-25-2012, 09:28 PM   #4
DDC
DDC's Avatar
Yep I opened the tabs but DW says it's still to loud.
Old 04-25-2012, 09:41 PM   #5
onetonford's Avatar
My old fiver had the reostat switch and worked fine still seems loud either way thou. I think because not much to muffle the sound.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
fan
