Old 04-22-2008, 07:27 AM   #1
Pulling For Fun
lorencherylp's Avatar
Subwoofer Cabinet Modification
FR uses a reverse hinge to secure the cabinet door where the subwoofer is located. I removed this hinge (Still need to fill the screw holes). I then located a similar door handle (match door above) and installed. I installed a door latch. There is a square hole on the left inside. I had some peg board, so cut a piece to fill the hole, after tucking in the wiring. I then needed to protect the 8 inch subwoofer. I looked for a speaker cover but couldnt locate one, so I got a under the shelf wire shelf at walmart, I cut it up and made a few bends to use small screws for attachment to the speaker front.
The mod gave a space to tuck a few thing in. Will still not want to block the front of the speaker. Also, the L bracket installed at factory was not screwed to floor, however the screw was laying next to the bracket
The sub is top heavy so still seemed to want to tip fwd, so I secured the top of the sub to remedy.
Happy Camping to one and all.
Loren and Cheryl
IA
Name:	FR Subwoof mod (1).jpg
ID:	827   Click image for larger version
Name:	FR Subwoof mod.jpg
ID:	828   Click image for larger version
Name:	FR Subwoof mod (2).jpg
2007 Dodge Ram Laramie 1500 4X4 Quad Cab Hemi 3:92
Superchips Programmer/Dynomax Exh/drilled airbox + K&N
Equalizer Sway Control/Backflip Tonneau, 20" American Racing Mags
Hellwig Pro Series Springs/Ultra Fab 3502 Elect. Tongue Jack
Tandem Honda EU2000i Generators
2008 829FKSS
Dodge Magnum Hemi/72 Chevy Nova 454
lorencherylp is offline   Reply With Quote
Old 04-22-2008, 07:42 AM   #2
Thanks for some Ideas, I now want to install a Bose system in my camper. My 06 did not come with a surround sound Stereo just that cheap Concertone thing that I already removed when I installed the 32" TV. That's a good Idea you came up with!!
Old 04-22-2008, 08:45 AM   #3
KyDan's Avatar
Good idea and "a picture is worth a thousand words" applies here-
Thanks!!
We've noticed our trailer has lots of places where they've waisted
perfectly good storage space.
We have areas under the sofa and under our dinette seats where
there is a space much larger than the little drawer they stuck
in there.
We will be looking at each one, in turn, to try to find ways to
salvage those lost space areas.
Our previous trailer was smaller but actually had more inside cabinet
storage space. We miss the storage!!
Thanks for sharing!
Peace!
Dan & Rita D
Blue Ox WD hitch
2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-28
Old 04-22-2008, 08:46 AM   #4
Pulling For Fun
Thanks, when you install the Bose, wouldnt mind seeing some pictures. Also, the 32 in. TV sounds good, can you post a pic?
2008 829FKSS
Old 04-22-2008, 10:09 AM   #5
The pic of 32" TV are already posted under MODS AND UPGRADES. When I find the best way to run the speaker wire for the Bose, I will post the pic.
Old 04-22-2008, 08:15 PM   #6
powerboatr's Avatar
very nice reclaimed storage
i cant believe the level of ugliness the install had before you filled the gapping square hole.
great job
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-23-2008, 04:16 AM   #7
I'd say good job also. However, I would watch what you put in there cause your probably gonna get some really bad vibrations off of anything stored close to the sub. I'm betting it doesnt have much power, but still it's all bass so anything will probably rattle that's next to it.
eandsphotography is offline   Reply With Quote
Old 04-23-2008, 09:34 AM   #8
Pulling For Fun
You are correct eandsphotograpy. I will have to choose the items stored there carefully. I am thinking dog leashes, towel to dry their feet, stuff like that. And I dont intend to block the front of the speaker either. Wife.com found a shallow plastic basket to go in front. May keep all the remotes for TV, Concertone, XM in the basket?? Happy Camping!
2008 829FKSS
