Old 11-11-2015, 10:30 AM   #1
Super Chip or those like it
Has anyone used a Super chip or something like it to improve towing. I am close to the limits of my TV capabilities when fully loaded but not over, I have a couple of hundred pounds to spare. I thought using one of these may give me some more wiggle room. Has anyone used these for a GAS engine, if so what are your thoughts, did you see improvement?
Airborne is offline   Reply With Quote
Old 11-11-2015, 10:50 AM   #2
Flybob's Avatar
Usually TV limitations are based on Non engine related properties such as brake capacity, and chassis and drive train capacity. Adding a tuning chip may provide more power but not impact the mechanical limitations listed above.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-11-2015, 10:52 AM   #3
jeff64's Avatar
I don't think just a "chip" EPROM change will do what you want without being able to get more air into the cylinders or be able to get the air out of the cylinders more efficiently $$$. Anybody I've seen try to get more out of and engine has gone to new induction and exhaust systems. Ford has a novel idea to get more from small displacements. They call it Ecoboost!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-11-2015, 12:08 PM   #4
What vehicle is your TV? Tuners can and do help with towing as they improve the engine tuning and transmission shift points.
Just an example, 5Star tuning for the 3.5 Ecoboost gives, on average, 50 HP and 50 TQ to the wheels. These are dyno'd results, not fictitious claims like a K&N air filter.
Hemifever tuning with a DiabloSport Trinity tuner on a 5.7 Hemi will get you around 30 HP and 30 TQ to the wheels. Shift points are also dramatically improved.
Most modern engines have plenty of headroom for intake and exhaust to get air in and out. They are simply tuned down to comply with fuel economy and emission standards.
If you do decide to get a tuner I'd recommend spending the extra bucks for a programmable tuner with custom tuning. Like the DiabloSport tuner with HemiFever tuning you get lifetime tunes from HemiFever. They'll send you custom tunes based on your application, be it towing or performance, and tailored to any mods you'd have, like intake or exhaust work.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 11-11-2015, 12:13 PM   #5
A tuner can and will improve towing CAPABILITY. However it will not Increase CAPACITY
I.E. Your current load may be towed more efficiently, but adding a tuner won't let you to more weight
jeeps4fun is offline   Reply With Quote
Old 11-11-2015, 12:14 PM   #6
My TV is a 2014 GMC Sierra SLT Z71. Max tow on it is 9600 lbs. My new 2016 Flagstaff is an 8321 KBS which weighs in at 8004. I bought this off of a Rockwood/Flagstaff 2015 model which shows 7300 lbs. Was surprised when I saw the 2016 being heavier. Still trying to get a reason why the weight increase. I am wondering if it was a correction to literature more than anything else as nothing else with the unit seems to have changed.
Old 11-11-2015, 12:27 PM   #7
asquared's Avatar
Is the 8321 weight a scaled loaded weight, a sticker weight on the unit or a brochure dry weight? Propane, batteries and options add weight above brochure weights. The trailer will then weigh even more once you load it with your stuff. If you are that close on towing capacity , I'm wondering where you stand on payload.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-11-2015, 12:32 PM   #8
A32Deuce's Avatar
I have a K&N cold air intake and a Banks program installed. Big improvement and pleasure driving. No more 10 mile per hour spread going over overpasses.
A32Deuce is offline   Reply With Quote
Old 11-11-2015, 12:33 PM   #9
asquared; i'm with you on this and that is my concern. I take delivery of the unit early next month and there is a scale right next to my dealer so I am going to have the unit weighed. Then I will just have to be real skinny for the next 1.5 years with what I put in it as I am intending to get a more capable truck in the future. Not a huge issue as we camp almost all the time with our kids who have trucks and can carry the generator, extra gas, extra water. Its a bit of an inconvenience but not one that can't be over come. Shoot, I may even pull the trigger on a TV that can pull more sooner. Was just thinking there might be a way to increase my capacity without moving up in TV sooner as I love my current TV and it only has 12K on it.
Old 11-11-2015, 04:08 PM   #10
Camper Less Camping
Cajun Po-Boy's Avatar
You won't be impressed with a tuner on a gas engine, the increases in HP and torque are so minor...IMO, hold onto your cash and wait for the next opportunity to purchase a more capable truck/powerplant
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
