I have no idea which fridge you have but on mine I was able to replace the leveling feet with bolts and secured it from beneath. It hasn't moved since.
It should have reversible doors, so I'd fab a thin piece of metal that would bolt into the unused top hinge bolt holes to secure it from tipping over. You could probably build one for both sides and just bolt through it and the hinge on the used hinge side.
Gotta go campin!
Did you put something at the outside access door to cover it? Wonder if I should keep it as is to help with heat dissipation.
Don't forget you'll also need to figure out a way to keep the fridge doors closed while traveling RV fridge has latches. Residential fridges typically do not
"The answer may not lie at the bottom of a bottle of wine, but you should at least check." ― Unknown
Add a corner (L) bracket to frig before sliding I to place and attach to wall. And remove base and screw into floor is how mine is I stalled onto slideout
Sure would be cool to see some pics of finished job [emoji4]
