Old 06-05-2014, 07:10 PM   #1
2014 XLR 27HFS
Surge Protector
Reading a lot of threads on this site about the need for a surge protector, I decided to put one in. One thread in particular showed using 30A couplers on each side so you could bypass it if needed. Very smart, so I copied it.
Basically, you put a male 30a coupler on one side and a female on the other. then put another set in the power line leading to your converter. Luckily, my toy hauler came with a transfer switch, which made it easy.
ID:	54430   Click image for larger version
ID:	54431   Click image for larger version
Name:	3 wiring.JPG
ID:	54432   Click image for larger version
Name:	4 wiring.JPG
ID:	54433   Click image for larger version
Dave & Audrey
dave961 is offline   Reply With Quote
Old 06-06-2014, 05:57 AM   #2
davel1971's Avatar
I've thought about doing it that way too, but 2 pairs of 50amp plugs would not be cheap.
David & Lynn
Old 06-06-2014, 07:42 AM   #3
TURBS's Avatar
If you watch ebay you can in fact get them cheap.
I found a set of 4 50 amp twist locks for my friend for $70.00
TURBS
"Sabre owners united"
Old 06-06-2014, 11:08 AM   #4
2014 XLR 27HFS
Two pairs of 30a plugs cost me $60 on Amazon. The surge supressor was about $250. After reading the horror stories on this site about power issues, the price was worth it to me.
Dave & Audrey
Old 06-06-2014, 11:35 AM   #5
TURBS's Avatar
Another frf member recently picked up a set of 4 30 amp plugs for $38.00
TURBS
Old 06-06-2014, 11:38 AM   #6
davel1971's Avatar
30amp plugs are WAY cheaper then 50amp
Sent from my SCH-I535 using Forest River Forums mobile app
David & Lynn
Old 06-07-2014, 07:08 PM   #7
Explorer
Notto bring down this post but for 3 years I have been watching posts and trying to understand the positive in connectors. My positive, not trying to hurt any feelings, is money and time. I don’t understand why you would do this inside the camper; they sell the unit for outside the camper w/connectors and it cost more its also weather proof.
Is it bad to put in connectors 30amp or 50amp , absolutely not it works great but why, they cost a bit and have to be more work(7 x3=21 connections instead of 3x3=9(_x4 for 50amp)) . If you are moving this device between multiple campers weekly/monthly/yearly it could save several minutes or if you need to do it while the wires are HOT.
For me, I pulled the wires out from the converter and installed in the unit, added 2ft of wire(x3; which you need any ways) from unit back to converter and done. Well not exactly, I ran the signal wire for remote display next to the heating ducting, fished it up the wall and out to where all the other displays and controls are(this took more time than the main install). Looks great and makes me sleep better at night.
Am I missing something with connecters? Even if I pull this unit for my next camper the original wires will still fit or even easier wire nuts and tape.
I want to learn, that’s why I’m here…. I have spent several nights trying to find the better…..
It all works and it makes good sense to have an A/C monitoring unit. Maybe there is no bad way, just do it. I figure it’s like paying insurance; you hope you never need it & might never need it, but so glad you have it when you do need it.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 06-07-2014, 08:24 PM   #8
2014 XLR 27HFS
To me $60 is no big deal, I live in the lightning capital of the world. If I'm in the middle of nowhere and something goes wrong with the unit - or if it takes a surge and fries - I can bypass it in minutes. When back in town, buy a new one and snap it in. But, to each his own. if you feel you will never have a problem with it, or don't mind rewiring when you do, then hard wiring is the way to go.
Dave & Audrey
Old 06-08-2014, 10:56 PM   #9
Canadian Member
itat's Avatar
I just order the PI EMS-HW30C. What is the NEMA # or Hubbell part # for the 30A plugs? I looked on eBay and saw plugs rated at 125V, 250V and 480V. Is there any need for plugs rated higher than 125V?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-09-2014, 07:25 AM   #10
TURBS's Avatar
L 5 30 I believe.
TURBS
electric, modifications, surge guards
