Old 05-28-2015, 10:46 AM   #1
Suspension Enhancement
Thoughts/Suggestions:
2010 GMC Sierra 1500 w/5th wheel.
I installed Timbrens on rear which gave me a very rough ride over bumps but helped the rear sag.
Remove Timbrens and installed rear air bags. Inflated to 35psi also tried 50psi. There seems to be more sway but the ride is better.
Ideas Please?
mfMcFroggierPod is offline   Reply With Quote
Old 05-28-2015, 10:50 AM   #2
If you still have P rated tires, I would strongly suggest some LT LR D or E tires.
Old 05-28-2015, 12:31 PM   #3
TURBS's Avatar
I'd have to agree.
Most likely a p rated tire issue.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "9 nights"
Old 05-28-2015, 05:48 PM   #4
I will consider the tire type change when time comes to replace them.
Good Idea, Thank You
Old 05-28-2015, 05:51 PM   #5
I just got back from a short trip, set air bags at 80 psi and it was awful. Made suspension to stiff.
50 psi seems to be about right.
Any thoughts on aftermarket sway bars? Dealer said, one is not available from GM.
Old 05-28-2015, 06:01 PM   #6
TURBS's Avatar
You didn't answer about the tires.
If you have p rated tires no suspension mod will help .
TURBS
Old 05-28-2015, 06:14 PM   #7
They are P rated tires.
Your probably right on track with the LT vs sway with the P's. All my other trucks had LT's.
Old 05-28-2015, 06:15 PM   #8
If you have p rated tires no suspension mod will help. TURBS
Agree 100%. As long as you have P tires on the truck, you will have sway regardless of any & everything you can add to the truck. Listen to the posts of experienced folks. You're fighting a loosing battle.
Old 05-28-2015, 06:33 PM   #9
My original reason for the mods was for tail sag. It seems I'll either get a harsh ride or a little sway. The add-on did solve some of it but created others...
And why is it that manufactures don't put LT's on 1500 trucks? More than likely they will be used to tow or haul loads.
Do it right the first time...
Just buy a 3/4 ton truck like I had before.
Thank You for the input, it is much appreciated.
Old 05-28-2015, 06:50 PM   #10
Ford Idaho's Avatar
A one ton is not much more money over the 3/4.
Go to one of the big three and build two, one a 3/4 the other a one ton.
suspension
