Old 08-30-2009, 10:46 AM   #1
jdeeter's Avatar
Table base conversion
I am looking to install permanent pedestals on my table which is in the slideout. Question is how long should the screws be? The base uses # 12 screws and I could not find 1" at Home Depot, bought 1 1/4" screws but don't know the thickness of the flooring in the slideout.
Jim & Eileen
Silverado 1500 Crew Cab, 5.3 ltr, prodigy controller.
2009 Rockwood 2604.
Running mates Max & Kate Chihuahua's
Hobie Kayaks on Thule rack on truck
Retired Army EOD
jdeeter is offline   Reply With Quote
Old 08-30-2009, 11:53 AM   #2
i did the same conversion but my table is not in the slide. i would say your 1 1/4 screws are too long. 3/4 inch screws would be more like it. maybe someone else will chime in that has completed the mod in your model. good luck. i just reused the screws that were holding the folding legs under the table. check how long they are.
skidoonut is offline   Reply With Quote
Old 08-31-2009, 12:50 PM   #3
jdeeter's Avatar
Thanks, good idea to reuse. also will give me a reality check on sizing.
Jim & Eileen
2009 Rockwood 2604.
Retired Army EOD
Old 09-02-2009, 10:51 PM   #4
AKA KE2DX
Don and Elaine's Avatar
Just completed the table mod in my 831fkbss and my table also is on the front slide. I found that #10 3/4 in. screws did the trick. I was able to lift the carpet and measure the thickness of the floor and determined that it was between 5/8 and 3/4 thick. Decided to go with the 3/4 in. screws and it worked like a charm.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
Old 09-13-2009, 03:29 AM   #5
Where can you get the hardware for this mod. I want to do the same but can't find the hardware.
8261ss is offline   Reply With Quote
Old 09-13-2009, 10:00 AM   #6
AKA KE2DX
The table flanges and posts came from camping world, the screws were from Home Depot. Very easy mod...completed in under 1 hour and DW loves the fact no more spilled food
