Old 08-12-2009, 09:14 PM   #1
AKA KE2DX
Don and Elaine's Avatar
Table Mods
I have a Flagstaff 831fkbss and I want to remove the folding legs from my table as I find the table to be very shaky (more spilled coffee than I care to remember). I thought I remembered seeing a post where someone removed the legs from the table and replaced them with a removeable 2 tubular post system that bolts to both the floor and the underside of the table using 2 flanges. The table is located on the slide out and I am not sure about drilling into the floor to mount the flange that holds the post to the floor. I was wondering if anybody has done this mod? Anything to watch out for, etc
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
Old 08-12-2009, 10:47 PM   #2
here is a link to the post you are talking about. i am the one who added the posts and got rid of the legs. one of the best mods i have done. Question regarding dinette
skidoonut is offline   Reply With Quote
Old 08-13-2009, 07:19 PM   #3
AKA KE2DX
Did you drill thru the floor or did you use Lag type wood screws to anchor the base plate down? I have carpeting and I dont want to rip it up, just want to put the flange down on top of it and make sure its still secure..What size screws did you use???
Old 08-15-2009, 08:38 PM   #4
i used a hole saw for the large center hole and used wood screws to hold the bases to the floor. that is how they are normally installed in the floor. you will have to trim the carpet back from the karge center hole but not to far so the flat ring will still hold the carpet down when you screw the mount down. good luck. it was easy. i spent lots of time measuring for center and how far from the wall to make sure the table was in the position i wanted and well supported.
