Old 04-11-2015, 08:57 PM   #1
Tank Heaters
How difficult is it to install Holding Tank heating pads?
My new Flagstaff Ultra Lite 23FBDS did not come with "Tank Heaters." I'm just wondering if I should add them. If added, 3 pads? (Black, gray and fresh water") Normally don't start camping until April 1st and am winterized by November 1st.
Thank you in advance
vinceigo is offline   Reply With Quote
Old 04-11-2015, 09:06 PM   #2
If you winterize and drain the tanks, you don't need them unless you plan on camping is sub freezing weather.
Old 04-11-2015, 10:53 PM   #3
It will be a job to do so. If you have an enclosed underbelly that is quite the job to get on and off as well as the wiring to a panel etc. Like old coot said not necessary if you don't camp in sub freezing temps. Just make sure they're drained before freezing temps and it's all good.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
heater, tank
