Old 05-03-2010, 08:04 AM   #1
Telescopic Flagpole On Back Of Camper
The pole is a telescopic painters pole, with a fiberglass lower section. as you look at the 1st pic it the tan color pole just to the right of the vertical ladder support. The pole at this point is in it's travel position and if you look close you can see the galvanized pipe clamps, there are two. As you look at the top of the pole you will see a round ball, this is a plastic softball, it was painted gold but I used the wrong paint so it came off.
To mount the plastic ball I had to drill a hole in the ball big enough to slip over the threads where a roller would go, then drilled another hole on the top of the ball so that I could put a nut over the threads once the ball was in place. I took an old paint roller and cut the end off of the handle where the threads are to secure the ball from within by using a pair of needle nose plires, then installed a rubber plug at the top of the ball.
The 2nd pic shows how the base of the pole was mounted. I had to use a cover plate from a 1900 electrical box, the reason for this is because the bumper was not long enough to support the bottom of the pole, as you can see I used a ladder support from an above ground pool, or what might be called a deck mount support.
The 3rd pic shows the finished, the flag that is on there is a 3x5. I can display two 3x5's at one time or any combinations depending on size.
The painters pole is a 10' pole that will extend to 18', I installed a pulley at the top so I can raise the flags from the ground once the pole is extended. I installed two brass spring hooks that are normally used on flagpoles but they are a little smaller. In order to add extra flags I connect the two or more flags with a double brass spring hooks and the are install between each flag.
mtnguy, this is how I did mine.....This Mod started out as a telescopic pole for a Direct TV dish but the problem was that my RockWood just keeps on ROCKIN so the higher I go with the dish the more sway there is, so now It is a flagpole. I do have a hole drilled in the bottom of the 1900 cover plate so I can run wire from the bottom of the plate and up on the in side of the pole so that I can add a light to the top of the flagpole for a night display or mount a solar light.
ID:	2460   Click image for larger version
ID:	2461   Click image for larger version
Old 05-03-2010, 10:22 AM   #2
milzat's Avatar
milzat is offline   Reply With Quote
Old 05-03-2010, 10:56 AM   #3
MtnGuy's Avatar
Great lookn' setup, Wade.
If I had seen this before I did my mod, I would have copied you.
Old 05-05-2010, 09:49 AM   #4
Looks Great.
Bob and Teresa is offline   Reply With Quote
Old 05-07-2010, 11:48 AM   #5
MikeInColo's Avatar
Excellent Mod!
That is a great idea!
There have been times when I'm returning on our jet ski and all the campgrounds along the shore look the same--it would be nice to have a flag that can be run up and recognized easily.
MikeInColo is offline   Reply With Quote
Old 05-07-2010, 02:11 PM   #6
One other thing that is important that I forgot to mention, Please forgive me, to Honor those that serve in the US Armed Forces and for those whom have died for this Country, not only in battle but at the hands of some sick people that like to take life for fun, and the first thing come to mined is 911 and the Police and Fireman that died trying to help. I can fly the US Flag at 1/2 staff in there Honor.......
Old 05-07-2010, 02:37 PM   #7
NWJeeper's Avatar
Nice job Wade. I need to figure out something like this but put a wind generator on top of it. I have a motor, need a blade and a pole. We just got back from 4 days of dry camping and had winds close to 40mph for two of the three days. Would have made a lot of power.
Ed & Wendy
www.nwjeepn.com
Old 05-07-2010, 03:02 PM   #8
milzat's Avatar
I fly my American Flag and LSU flag when ever I can.
I bought this 23' telescoping flagpole a SAM'S Club about four years ago. $53 with stand. It telescopes down to 4' for storage. In this photo, I have the stand placed under the rear stabilizer foot. On my prior TT, I would place it under the tongue jack.
Old 05-09-2010, 07:49 PM   #9
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Gotta love those flags...nice work!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-09-2010, 08:30 PM   #10
powerboatr's Avatar
cool idea
how to you extend it? do you have to climb up to extend it?
i like your idea, i have been looking for a sensible cost effective aproach for a GOOD flag pole
thanks
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 05-09-2010, 09:15 PM   #11
milzat's Avatar
Originally Posted by powerboatr View Post
cool idea
thanks
Twist the flag pole sections to unlock, slide the pole sections to extend, twist to lock, just as you would an extendibles car wash brush.Sam's Club.
For those of you with a ladder, Click here.
Old 05-10-2010, 06:46 AM   #12
I do have do get up on the ladder to extend my pole and lower it but it stays on the camper at all times. I do like the way Mike's works by standing on the ground to raise it.
Old 07-11-2010, 01:17 PM   #13
Pourme's Avatar
Flag pole
rockwood06.....I am copying your flaf pole mod, thanks for the tip!.... Where did you purchase and how did you attach the pully? It obviously has to be securely attached!
Thanks!
"The government cannot give to anybody anything that the government does not first take from somebody else."
Dr. Adrian Rogers
2017 Rockwood Ultra Lite Signature 8289WS
2005 F-250 Super Duty diesel
Pourme is offline   Reply With Quote
Old 07-11-2010, 03:37 PM   #14
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
I recently saw a flag pole on a camper that the holder was mounted to the camper bumper. If folded up and locked like the legs on a foldable table. I'd love to find something like that. I don't have a ladder, and I don't want the one on the ground to avoid tripping, or what have you. Has anyone seen that.
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 07-11-2010, 04:14 PM   #15
When I was @ MIS in June, I saw several RVs that had a flagpole mount that was attached to the rear bumper. The flagpole holder was then slid into the bumper mount. I didn't look close enough to see a brand name. I've made up my own mounting kit. I'm ordering a new fibreglas pole later this summer.
BTW, some race tracks will not allow metallic flag poles. Not sure how close this is checked for but there were a couple of chaps electrocuted @ Talladega a few years ago when raising their flag pole.
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 07-11-2010, 07:51 PM   #16
Pourme's Avatar
The pole I'm using has a fiberglass base section the extension that extends out of the fiberglass main body is aluminum...I will go to Lowe's tomorrow & see what kind of pulleys are available...
Dr. Adrian Rogers
Old 07-12-2010, 05:30 AM   #17
Originally Posted by Pourme View Post
rockwood 06.....I am copying your flag pole mod, thanks for the tip!.... Where did you purchase and how did you attach the pulley? It obviously has to be securely attached!
Thanks!
The painters pole was bought at Lowe's, as far as the pulley I removed the screw at the top of the pole where the threaded part is for the paint roller and drilled the hole a little bigger so that I could install an eye hook then open the eye hook to install the pulley and the n closed it back up. The eye hook is the type that has threads so I could install it with nuts on both sides of the pole.
Old 07-12-2010, 07:39 AM   #18
Pourme's Avatar
rockwood06 Thanks for the info!...I am off to Lowe's to look for the parts!
I will post pics when project is completed......
Dr. Adrian Rogers
Old 07-27-2010, 07:54 PM   #19
Pourme's Avatar
Thought I would post some pics of my flag pole in action!
Name:	DSC02007 (Small).JPG
Name:	IMG_0415 (Small).jpg
Thanks for the tip...Got several positive comments!
Location...Holden Beach Pier Campground...North Carolina...
Dr. Adrian Rogers
Old 07-28-2010, 05:24 PM   #20
Attachment 2977
Attachment 2978
What did you put on the top of the pole. By the way it looks great
