Old 03-19-2012, 09:44 AM   #11
TURBS's Avatar
Ok so I've had it EASY!
that's why I was lost within this post.
Old 03-19-2012, 10:30 AM   #12
Herk7769's Avatar
While my TV outputs were tied to the Concertone inputs, the maintenance department did not have the correct VESA MM screws to attach the swing arm mount.
They just screwed in regular camper type sheet metal screws; destroying the mounts on the TV and ensuring the TV would never be tight to the mount. It is always crooked and can never be fixed. (morons)
Given the outcome, I would have preferred they left the TV in the box.
One of a very long list of maintenance screw ups at my, so called, dealer.
HAM CALLSIGN - KC3FFW
Old 03-19-2012, 10:36 AM   #13
I have the Touch Audio unit. When using the DVD player sound comes through the spaekers in the ceiling. When on normal TV (Dish Satelite) no sound through the speakers. I have tried several different ways and can't get it to come through the speakers. It sounds like you can hook into the ipod port somehow and get it to work. This is where I am lost once people start talking about various cable configurations. Maybe someone has some pictures or part numbers?
rkswyo is offline   Reply With Quote
Old 03-19-2012, 11:25 AM   #14
Herk7769's Avatar
Hate to say it again Todd, but every camper is different.
We need YOUR pictures and model numbers to help you.
Could you sift through your info that (maybe) came with your camper?
If no model numbers then photos of your equipment will help.
You may need to connect the Dish receiver's audio output to the Touch Audio's inputs if there is no audio out from the TV. Some receivers simultaneously output to more than one set of connections.
Photos will help us help you.
If this still seems like Greek, them perhaps a more knowledgeable friend or a trip to the local car stereo place would not be out of the question.
There is no shame associated with doing so.
Old 03-19-2012, 11:40 AM   #15
I am not at home right now but as I remember it is a model 300xx. The manual is very basic and dosen't show any connections. Internet searches come up with nothing. My Dish reciever is a model 322. I will get the exact model of the Touch Audio tonight.
Old 03-19-2012, 11:43 AM   #16
[QUOTE=herk7769;171241]Hate to say it again Todd, but every camper is different.
I will try this. I don't think I did this yesterday. I worked on sorting all the coax stuff out to get the Satelite working. Not quite sure why they can't label everything from the factory!
Old 03-19-2012, 12:03 PM   #17
Herk7769's Avatar
More Info:
Your Manual
http://www.lci1.com/images/Flyers/Ow...ouch-audio.pdf
OK, there are two ways to get TV sound into your Touch Audio.
a 3mm stereo input on the front (#7 labeled as MP3/IPod) connected to the audio out on your TV
OR
The side inputs page 8 (you will need to remove the Touch Audio unit from the cabinet to get to these) labeled AUX IN L and R.
Now we need to check your TV
Still looking...
Old 03-19-2012, 12:50 PM   #18
Herk,
This is all starting to make a little more sense. I am going to pull the unit tonight and see what it looks like. There are AV connections on the ceiling that I believe were run from the side inputs you refered to. As far as the 3mm stero input goes is this a single cable or an adapter to the regular video cable? I appreciate your help and I am anxious to dig into it tonight.
Todd
Old 03-19-2012, 01:21 PM   #19
Herk7769's Avatar
Originally Posted by rkswyo View Post
Herk,
This is all starting to make a little more sense. I am going to pull the unit tonight and see what it looks like. There are AV connections on the ceiling that I believe were run from the side inputs you referred to. As far as the 3mm stereo input goes is this a single cable or an adapter to the regular video cable? I appreciate your help and I am anxious to dig into it tonight.
Todd
Todd, If you have a digital camera I REALLY could use some photos that panel in the ceiling; of the back of your TV; and back of your Dish Receiver. I could actually give you a link to the correct cable you need and how to plug it in.
I would LOVE to see how your cables are hooked up now.
Is this what is on the ceiling?
Old 03-19-2012, 01:29 PM   #20
I will try to get some pics tonight. Your pics are different than what I have. Mine just has the Right, Left and Video jacks. Just one of each. I had them set me up for satelite but it wouldn't work the way they had it wired. The outside cable/satelite connection went to the powered antenna. Satelite will not work through a powered antenna so I unhooked all that and just used the red coax coming from the outside to go to my Dish Receiver. Ther is a grey coax that takes the Sat to the beroom. I will never use the power antenna anyway and if I had to it wouldn't be a big deal to hook it back up.
