Old 03-18-2012, 05:52 PM   #1
FreedomTracker's Avatar
Television & TT Speakers?
Does anyone know if the TV can be plugged into the TT built-in speakers?
I have a 2011 Rockwood 1809s. The sound quality of the TV by itself is weak and I'm sure would sound better if I could easily utilize the TT speakers...
FreedomTracker is offline   Reply With Quote
Old 03-18-2012, 06:00 PM   #2
wfmdfm's Avatar
More info will be needed to make a determination. What is the TT sound system? You need to figure out if the current sound system is capable of audio inputs and also if the TV has audio outputs. If the answer is yes to both it could be as simple as installing a audio cable between the 2 components.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 03-18-2012, 06:34 PM   #3
GASPEDDLER's Avatar
Exactly, there are a few possible methods of connecting tv audio to your speakers. My tv can hook to my speakers thru my genesis/concertone sound system via RCA's, Aux cable or optical audio cable. What sound system do you have? What type of audio outputs are available on your tv? Are you getting your tv signal via satellite?
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 03-18-2012, 06:57 PM   #4
JoeR's Avatar
I was able to do this with a custom jumper. I ran the RCA audio out on the TV to an RCA to 3.5mm adapter. Then I used a regular 3.5mm jumper wire (IPOD adapter) to go to the stereo in for the IPOD on the front of the Genesis. Turn on the input and you have TV thru the stereo.
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 03-19-2012, 07:16 AM   #5
Herk7769's Avatar
If your TV only has a digital output, a converter is needed to convert the fiber optic output to L/R (white and red) RCA analog for the TT system.
Sewell A-BLOQ Analog to Digital Audio Converter on eBay!
This one works just fine. You will also need to buy the cables.
A good source for inexpensive cables is:
www.cyberguys.com
HAM CALLSIGN - KC3FFW
Old 03-19-2012, 08:05 AM   #6
You could use a wireless transmitter, the kind that you would use to play an MP3 player through your stereo. It simply plugs into you cigarette lighter outlet, connect the TV audio outs via an RCA to 3.5mm stereo jack cord, and your tv will play through the stereo. You can buy them for around $20.00. I recommend looking for one that offers the ability to change the transmission frequency. If your TV doesn't have RCA outs you can use the headphone output.
Like this; http://www.amazon.com/gp/aw/d/B0012399AG
Bakker is offline   Reply With Quote
Old 03-19-2012, 08:27 AM   #7
I would like to do this but you guys are speaking a foreign langauge to me! I am a little electronically challenged when it comes to this stuff.
rkswyo is offline   Reply With Quote
Old 03-19-2012, 09:14 AM   #8
Herk7769's Avatar
Originally Posted by rkswyo View Post
I would like to do this but you guys are speaking a foreign language to me! I am a little electronically challenged when it comes to this stuff.
Pictures or model numbers would be helpful.
Every camper has different equipment in it.
We can be more specific if we knew what you were dealing with...
Old 03-19-2012, 09:20 AM   #9
TURBS's Avatar
I guess I'm not understanding this post all together.
Both my tt and 5er I was able to play sound through the speakers
By simply putting entertainment center on aux1.
Its a must when the air is on.
what am I missing about this post?
Old 03-19-2012, 09:32 AM   #10
Herk7769's Avatar
Apparently not all campers were hooked up this way. I have had to help several other folks over the years where the outputs of their flat screens were not connected to the AV system of the camper.
The TVs are shipped to the dealer in a box. They are installed at the dealer as part of the prep. Not all dealers have an "AV Department" to figure it all out.
