03-07-2011, 11:44 AM
RV Newbie
Television mount
I am looking at adding a 21" flat screen mount to our RV. I sorta like this mount but wanted to hear any other options before I ordered this one.
MorRyde TV1-021 Double articulating TV Wall Mount
It is good for 25 pounds and the arm extends up to 18" and provides full motion swing, tilts 10 degrees, and swivel. We'd watch the TV mostly in the lock position but need it to move around when we open cabinet doors either side of of the TV.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
03-07-2011, 11:57 AM
Moderator
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
03-07-2011, 01:40 PM
I have had luck with the Ollo mounts brand, has shock absorbing and also lock mechanisms.
Can't figure out the linking yet, but one of them on amazon.com is listed as:
OLLO MOUNTS: 30-46" Swivel / Tilt **SHOCK ABSORBING** **FINGER TOUCH MEMORY TILT** **PATENTED ARM LOCKING MECHANISM** Flat Screen Universal TV Wall Mount (44N)
I never travel without my journal. One should always have something sensational to read.
03-07-2011, 03:10 PM
RV Newbie
Originally Posted by mtnguy
i have looked at that one. how do you lock it down so it doesn't float around when you are driving?
03-07-2011, 03:17 PM
We have the MorRyde mount for the 23" flatscreen that we upgraded to. The locking mechanism works well, have not had it let loose in more that 3000 miles so far. The only concern would be the weight. I cut a piece of 1/2" plywood, painted that and mounted it with some wood cleats that i installed. Works good.
Goody Two Shoes and the Filthy Beast
2008 Chevy Silverado 2500HD
Duramax and Allison 6 speed
2012 Wildcat 282RKX
03-07-2011, 05:15 PM
Moderator
I use a bungee cord attached to the cabinet above it.
2008 Surveyor 263
03-14-2011, 06:37 PM
Check out www.monoprice.com they sell mount cheap.
03-24-2011, 08:36 PM
RV Newbie
well, after a great deal of debating I did order the peerless you suggested. I will be "inventing" some type of hold-down instead of the bungee solution you use.
03-24-2011, 08:57 PM
Moderator
I brought a locking cantilever mount from Camping World.
Locking the TV in place for travel is easy - no need to use cords or straps.
http://www.campingworld.com/shopping...er-mount/51564
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
03-25-2011, 02:35 PM
RV Newbie
Originally Posted by Terier
I would have used one like that, but this is going on the front of a cabinet and the wall mounting plate needs to be as short as possible, I'll probably make up some type of latch that holds the two arms together when it is pushed in.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 535 |
| 80 members and 455 guests |
| 02 rockwood, 4bnabird, 4Jeeperz, 64c10, 8261ss, Barnman1, Bearcat55, bfisher82, bob7794, bossplowman2, bouldercamper, buzzmonster, campfun, carsonizik3, ClampNfish, cstover, djorgensen3, DonCath25ds, DonG, Elidh, Emptypockets, Erniem, f1100turbo, fonzie, Freds342, fx4roo, gerrym51, GlacierGus, greti, grhodes50, Hack, hoffkm, ilovecamping, kenandterry, Kentdb1, kgmat, KKapa, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, Mkayers, NeilM108, NO3putt, Pa-cj5, patov6, Pinesman, Poppy Bill, PrairieBoy, prof_fate, punkaccountant, RattVader, RichN, RickV, Roamin Ovum, rschroe, Rsgtivr6, Rugged Brown, Russ, ryoucrazey, seatosea, ses, shiggs, Smithee, Sparkbark, SpringerPop, Stevea1956, terrystevens, tfennell81, tgarner2000, tonybab, torben, transamz9, troyt, vp22er, Walke, Whiteknight |
| Most users ever online was 1,025, Today at 01:04 PM. |
