07-16-2015, 03:46 PM
#261
Always Learning
Originally Posted by QCCowboy
Finally got my rail mate put on for the rear door. Works great and I now finally have a rail for the kids to grab on to. Will probably use that door a little more now. Took a little work and I had to remove some of the trim to drill the holes through the step frame, but got it all back together again.
Is it sturdy? Some of the reviews said it was iffy...
07-16-2015, 03:47 PM
#262
Rock solid. Have it strapped to the door handle.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
08-22-2015, 04:44 PM
#263
Tore out the outside kitchen counter top and put in corian. Got damaged from refrigerator defrosting in travel. Now the refrigerator door can open all the way without hitting the outside kitchen door!
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
08-22-2015, 05:29 PM
#264
That's beautiful!!! Nice job!!
2014 Crusader 295rst
2014 F150 Fx4
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
08-22-2015, 06:43 PM
#265
Always Learning
Originally Posted by Ksilvi
That's beautiful!!! Nice job!4
X2!
08-22-2015, 07:25 PM
#266
Nice job!. We are looking at a a outdoor kitchen in our upgraded Fifth Wheel. I was thinking of running the outside fridge on a invertor while travelling. No need for mega size batteries, run off charge lead from the truck.
B and B
08-22-2015, 07:29 PM
#267
Thanks guys.... Funny part to the story is there's a guy at our little "home" campground that works for a company that does millwork (cabinetry) for a few of the jobs I work on, including the one I'm on now. I asked him to check at work to see if they had a remnant of solid surface that I could buy, that would make the counter top. He asked, and told me to check elsewhere, they "wanted too much". So, I went to work, asked the GC's superintendent to see if there was any counter tops laying (was willing to settle for laminate) around that had come in wrong, that I could cut it out of. I told him what it was for, and that I really wanted something solid surface, to prevent having the problem again, and asked him to ask his vendor if he had any remnants laying around. The vendor sent it to the job site, with a tube of the adhesive, the same day. The guys on site cut it, and bonded a strip to the front edge (to double the thickness to make it look counter top thick), and I cut the sink hole. I was gonna do a stainless sink, but had a "brain fart", and squared off 2 of the cutout corners, instead of rounding them off, so decided to stay with the stock sink. I could've pulled it off, but I think the stock sink actually looks better with the Corian. Thought about doing a bar faucet, but like the quick connect hose option, plus I have the paper plate holder over the sink. Nice "free" mod!
LINK TO MY MODS
08-22-2015, 07:52 PM
#268
Guess I should have included a pic of the stock sink & counter top
LINK TO MY MODS
08-22-2015, 08:11 PM
#269
Always Learning
That outside/dorm fridge looses its cool *really* quick. I'm thinking more and more about this inverter idea for it. The biggest hassle would be running the electric line back to it- especially in my case since it is in a slide.
08-22-2015, 09:01 PM
#270
How much amperage does one if those little fridges use? Seems like it'd be very low
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
08-23-2015, 06:22 AM
#271
Mine typically holds temperature fairly well. The damage happened because it was at the dealer before the last trip, and they were supposed to keep it plugged in, and apparently their breaker tripped or it got unplugged, and I wasn't aware before hitting the road for 4+ hours. Here's the sticker on the back of my refrigerator. I've flirted with doing an inverter.... just haven't decided to dive into it.
LINK TO MY MODS
08-23-2015, 06:35 AM
#272
Oklahoma Proud
Looks good Steve!
10-26-2015, 11:10 AM
#273
Thought I would post another one here. The slam latches are pretty easy to bypass, and while I'm not as worried about protecting what is in there, I did have a problem where I could darn near open a basement door because of the gap between the door and the latch catch. Simple solution, put an o-ring underneath (both seals and rises the catch). Problem solved. Not sure if anyone else will have this issue, but it cost me somewhere in the neighborhood of $.50/latch).
I know this is a really old post but I had this same problem with one of my basement doors being able to be pulled open even when locked. I tried the o-ring fix and it didn't help.
What I finally did was take a square latch plate from a regular door, drilled some holes in it so I could line it up with the existing screws, and put it right on top the existing latch catches. It works perfect.
I didn't take any pics, but the latch plate looks something like this:
The one I used was a little longer and had more room past the existing holes.
11-23-2016, 08:42 PM
#274
Oklahoma Proud
Dang, its been over a year since anyone posted in here. Just went and winterized our sabre last weekend. I plan on using it some this winter and i wanted to speed up the winterization process for the future. (I forgot to take pics of my mod though)
Anyways, i cut a square flap in my cloriplast just in front of the wheels on the door side and found the water lines.
I then installed 1/4 turn ball valve shark bites on the lines just rearward of the kitchen sink t's.
This way after i winterized, i just shut the valves and now we can use the front water lines and winterize just them.
I believe last summer i deleted the house water filter since we just use the blue torpedo filter anyways. This also helps speed up my winterization!
Heres test hitching the camper to make sure the hitch is setup right for this truck. Probably taking it to a buddy place in a couple weeks.
11-23-2016, 08:47 PM
#275
Oklahoma Proud
Oh and Steve, if you still look on here.....
Im going to have to do an outside kitchen counter top mod too. My counter is swelling right in front of the sink a little and behind it was delaminating slightly when i was defrosting the fridge and it leaked out some water.
I think i will use fiberglass and gelcoat and just make a counter top, but i might order some carbon fiber and really trick it out!
11-23-2016, 08:56 PM
#276
Always Learning
If you make one, know that I may be through Oklahoma in the spring.
11-23-2016, 09:05 PM
#277
Always Learning
Ok, so mods to my 36QBOK.
I replaced a wood panel in the bunkhouse with a metal mesh. There are water lines to the outdoor kitchen that have leaked. The cold and hot happened back to back in cool-cold weather last January. I'm hopeful that this let's warm air from the room to them and keeps them from freezing.
11-23-2016, 09:08 PM
#278
Always Learning
We replaced the glass in the cabinet doors above the TV. We are Disney freaks and have quite a pin collection. It used to reside on a pin board that we sit on the top of the big slide in that room. But it was something we had to move every time we moved.
We plan on replacing the glass out of the doors above the couch. We won't do pin boards, but we'll take similar metal and paint it.
11-23-2016, 09:11 PM
#279
Always Learning
Added support/lift arms and a hinge to the bed in order to get access to a little more storage for off-season clothes.
I'm pretty happy with how this turned out.
11-23-2016, 09:14 PM
#280
Always Learning
Added a 1/2" layer of plywood to the lower bunk so that it didn't creak and scare me so much. I was afraid that we were going to put a foot thru the thin luan that was there before.
We are thinking of painting some roads for my son's Hot Wheels on it. Not sure yet.
